Vent windows.
Old Mar 15, 2004 | 06:02 PM
NewMexF250's Avatar
NewMexF250
Vent windows.
Has anyone ever taken the glass out of one of these and put in in a better frame? Some *&(^%*& threw a rock at my vent window and broke it. I have a good frame now with no glass and one frame with no handle to keep the window closed. Would it be easier to replace the glass or the handle?
Thanks guys
Ben
Old Mar 15, 2004 | 07:56 PM
daveengelson's Avatar
daveengelson
Removing vent window glass and handle is really not that difficult. Replaced couple of vent windows. Since the class is going to be replaced, do not need to be overly careful removing. I used a chop stick and got it started in one end then continued working it loose using a rubber mallet. Would not suggest using a lubricant, tends to swell the seal.
If you are referring to just the the handle, there is a small pin at the base of the handle that holds it onto the shaft. Using a small punch, push the pin through. If possible try and save the pin. If referring to tent window bracket and handle shaft, have replaced the hinge and assume would be same. Drill out the old rivets, replace the bracket, and secure using new rivets. Use a rivet that will not leave excess material and a flush as possible for the window to set in. Pop rivets will not work. Should be able to get rivets any hardware, or parts store.
Hope answered your guestion. Am sure there will be other member who can provide more info, and or suggestions.
Good luck,
dave
Old Mar 16, 2004 | 08:53 PM
cobraguy's Avatar
cobraguy
Ben I have a couple spares laying around. What side do you need?
Old Mar 16, 2004 | 11:30 PM
moiamiervous's Avatar
moiamiervous
Hey cobraguy I need a passenger side vent window
that's is if NewMexF250 don't need it ?? I don't want to step on anyones toes !!
EDIT- No parts trading in the forums, use email or PM. -Admin
Old Mar 17, 2004 | 07:19 AM
cobraguy's Avatar
cobraguy
Jerry do you need just the glass or frame and all.
I got my truck up there and brought it down to SD. My brother works for a towing company in Spanaway. My truck came from an impound auction for $250. I looked in your gallery cool truck is it a custom cab or did somebody just put on the chrome door handle pockets. Rich.
Old Mar 17, 2004 | 09:55 AM
NewMexF250's Avatar
NewMexF250
Thanks Rich. I actully scored some off ebay the other day. Thank you anyway !!!!
Ben
Old Mar 17, 2004 | 06:50 PM
moiamiervous
Hey cobraguy
I need the whole glass and frame for the vent window.
Old Mar 19, 2004 | 01:49 PM
cobraguy's Avatar
cobraguy
Jerry contact me at shelekelley@yahoo.com
Old Sep 2, 2004 | 09:55 AM
53Merc's Avatar
53Merc
Question Slant Cab Vent & Side Door Glass Installation Instructions
Does anybody have step by step (for Dummies like me ) instructions on lhow to install the vent and side glass so you don't have wind noise?
I have all the Dennis Carpenter Fuzzies, Division Bars etc... hey wait a minute, maybe I should call them and get a set of instructions?!?!
GW
Old Sep 2, 2004 | 12:42 PM
Tiremine's Avatar
Tiremine
Merc,
I bought all my door stuff form Carpenter also. If they sent you a catalog, check the back page. Mine has instuctions and pictures on the last two pages of how to do the install. If you don't have one I can try to scan the pages and put them in my gallery.
good luck
Iv'e just been sitting back reading the posts for a while. Thought I better post before Mr.T beat me up!
joedellcarter
17
Mar 19, 2017 11:20 PM
scottlathrop
Aug 2, 2015 08:04 PM
dagwood387
16
Jul 1, 2015 08:23 AM
DougofMontana
Jun 22, 2015 10:30 PM
ungerp
Jan 2, 2013 03:54 PM
