1978 - 1996 Big Bronco
5.0 Mass air conversion
Old Mar 3, 2004 | 10:36 PM
VernO's Avatar
VernO
Question 5.0 Mass air conversion
Dear People who are smarter than I am-
I have a 1987 Bronco fullsize, with the stock 5 litre in it. As far as I can tell, it is a california truck, but since it is an 87 and not an 88, it has the speed density set-up instead of the mass air. The motor is gutless, and I want to put a bigger cam to pull the 35's. I was wondering what all i need to convert to mass air. It has the 4-speed auto tranny. Can i use a 5.0 mustang computer with a truck mass air sensor from the junk-yard and then the wiring conversion? Should I just find a newer bronco in the junk-yard and strip the computer and mass air and then buy the wiring adapter? I read on the internet that it is not even possible to do a conversion to mass air with the 4 speed OD tranny? Thanks for the help.
-VernO
Old Mar 4, 2004 | 09:53 AM
DW2455's Avatar
DW2455
do a serch on the forums there has been alot of discusion on the subject, and few people have done the conversion you can probly find the info you need, and by the way summit racing and jegs both sell a complet conversion kit. Good luck DW
Old Mar 4, 2004 | 10:30 AM
Kemicalburns's Avatar
Kemicalburns
to run 35's a cam wont help . you need gears my friend. and 4.56's at that. just an fyi mass air didnt show up on broncos with 302's till 94. here is a web site with all the info you need on this as well.
www.fordfuelinjection.com
late
Old Mar 4, 2004 | 08:35 PM
VernO's Avatar
VernO
Thanks for the help. I have gears my friend, 4.11's to be exact and it is still gutless. the question was could i use a computer out of an 89- 93 mustang combined with a mass air sensor from a light duty truck or bronco. thanks for the help.
Canadianice
Dec 8, 2009 10:42 AM
ktp744
Feb 20, 2009 11:05 AM
forbeer
Nov 17, 2005 09:43 PM
gov2mod
Aug 13, 2004 01:21 PM
jesse460
28
Oct 30, 2003 03:13 PM
