Mass air conversion
Old Feb 18, 2009 | 02:41 PM
ktp744's Avatar
ktp744
Mass air conversion
I have a 1992 f-150 with a 5.0 v8 engine that i want to convert from speed density to mass air. I have a mass air meter, computer, and complete engine harness off of a 1994 f-150 with a 5.0 v8. If i put all the parts from the 1994 on the 1992 will it work or will the firing order of the 92 engine not match the 94 computer?
Thanks,
kt pulliam
Old Feb 18, 2009 | 03:38 PM
Conanski's Avatar
Conanski
You have 2 choices, rewire the injector portion of the '94 harness for the old firing order or change the camshaft to one with the new firing order. Personally I'd take option #2 because the stock cam is so pathetic, but that may be more work than you planned for. And don't let anyone tell you you don't have to match the injector firing order to the cam, the motor will never run right if you don't change it.
Old Feb 18, 2009 | 03:58 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I would not bother with this unless you plan on making the modifications to need Mass Air.
Old Feb 20, 2009 | 01:37 AM
Runboy's Avatar
Runboy
Aren't there supposed to be efficiency / mpg benefits to the mass air conversion as well?
Mike
Old Feb 20, 2009 | 08:49 AM
GlennFordx4's Avatar
GlennFordx4
I am planing this as well and would like to start getting parts together I know where there is a 94 to get some parts from but my truck is older and the auto trans is not controled by computer and the 94 is so what computer do I need to get I have a whole junkyard to choose my parts from.
Old Feb 20, 2009 | 09:07 AM
Runboy's Avatar
Runboy
I had come across this link which you may also find helpful on this.
Mike
Speed Density to Mass Air Conversion. F150, Bronco, Mustang.
Old Feb 20, 2009 | 11:05 AM
Conanski's Avatar
Conanski
In your case get a 5.0 mustang computer.
nobodyspecial
Feb 12, 2010 11:28 PM
Canadianice
Dec 8, 2009 10:42 AM
f350idi
May 23, 2009 06:04 PM
92beast
Feb 2, 2004 12:20 PM
noremac19
26
Apr 4, 2001 09:44 PM
