95 mass air conversion
anyone know where to get a mass air conversion for a 95 f150 with a 5.8 and e40d? will the fms lightning kit work? it is the only one i have seen that works with the e4od but i was told the lightnings have a different engine wiring harness. i need a setup capable of fueling a 500hp 426 stroker. The truck is now speed density i checked every salvage yard around and found no 5.8s that have mass air. i only found one truck that had a 5.8, all the half tons have 5.0 or 4.9 the three quarter and one tons have diesels
I'm talking about a 95 factory MAF truck (if they exist). If that doesn't lead anywhere, I believe Pro-M makes a conversion kit for the E4OD, check them out: www.pro-flow.com
I heard the enitre engine harness on the 93-95 Lightnings were different that the normal 351W w/ E4OD. It's worth a shot. Summit Racing is cool with their return policy. If it doesn't work send it back.
Worse case scenaro... search car-part.com for an engine harness that you need. I did a quick search and found 10pages of engine harnesses...I selected the last ment of "Wiring/ Misc"
are the factory maf trucks bank fired injectors or sefi could that be the difference in the lightning engine harness? the fms lightning kit uses 2 cpus piggyback, stock to run the trans and one for the engine. i searched the archives and found alot of posts from people wanting maf with the e4od but i found none that were sucsessful thanks, Jesse
Originally posted by jesse460
after posting in the lightning forum i have found out lightnings are speed density and batch fire not sefi the difference in th wiring harness are due to the different sensor placement in the gt40 intake. that means the fms kit should work
Doesn't that kit come with an odd harness that uses 2 computers, a set of 30lbs'hr injectors, and an 80mm MAF?
Do keep me informed on this for sure...I plan to buy a '95 Bronco within a few years with a 351W and an E4OD (the E4OD is way stronger built than a 4R70W) and assumed they came with MAF.
