1978 - 1996 Big Bronco
Fuel Pump pressure relief
Old Feb 28, 2004 | 08:45 PM
JTs Bronco's Avatar
JTs Bronco
A quick question for anyone. I have a 1990 bronco 5.8L I need to replace the fuel pump in the tank. After reading the Haynes Manula it says relieve the pressure before dropping the tank. My question is the manual says use the inertia switch to do this , by running the engine until it runs out of fuel. My fuel pump is out so I can't run the engine, so how else can I relieve the pressure???
Old Feb 29, 2004 | 12:51 AM
justshootme84's Avatar
justshootme84
Read up on the inertia switch. Just trip it to relieve the pressure. There should be little or no pressure if the pump is bad. Don't forget to reset it before starting after you finish with the new pump.
Old Feb 29, 2004 | 09:18 AM
JTs Bronco's Avatar
JTs Bronco
I have read up on it but it says run the engine after you push the switch up. If I can't run the engine how will I release the pressure. The pump just went out so does that mean I probably have low pressure? I'd hate to find out the hard way..
Old Feb 29, 2004 | 10:19 AM
BillyBob69's Avatar
BillyBob69
If the pump went out..and it has been sitting for at least 24 hrs..then the pressure should be down....not completely..but enough..just dont wear anything you really like when you go to disconnect the lines. You will get a little spit but nothing to make a flame thrower out of.
Old Feb 29, 2004 | 10:25 AM
JTs Bronco's Avatar
JTs Bronco
Thanks Billybob...well then I guess it's time to drop the tank and get to work..wish me luck..
Old Feb 29, 2004 | 10:39 AM
BillyBob69's Avatar
BillyBob69
GOOD LUCK!!!!
Old Feb 29, 2004 | 06:10 PM
justshootme84
When I removed the gas tank and hp pump from my 88 Bronco, I could not start the motor either. I could not even crank it (no battery). There was no pressure in the system, though i did pop the inertia switch for good measure. You should have no problem. Even if there is a little residual pressure in the lines, it won't blow up! Just spits a little gas wherever you disconnect a line. The lines use a safety-type clip, but once you figure out how to remove them, it's easy. And good luck!!!
Old Feb 29, 2004 | 08:15 PM
JTs Bronco's Avatar
JTs Bronco
Thanks guys for all the help..I'll be picking up a new pump tomorrow and weather permitting should be under the beast soon..
Old Mar 4, 2004 | 08:59 PM
jacque_strap's Avatar
jacque_strap
Just in case anyone was wondering, to relieve the fuel pressure on Ford Vehicles w/ EFI (most anyway) there is a little cap on your fuel injector line, which runs on top of your block beside your intake manifold. This cap looks just like the ones to fill your tires - unscrew it and push down on the valve and a small amount of gas will squirt out. Fuel Pressure Relieved!
nitrobarry1
1997 - 2003 F150
Nov 30, 2016 08:48 AM
Ifdot
Dec 1, 2014 05:27 PM
MI Yeti
Jul 20, 2014 11:33 AM
DBGrif91
Sep 30, 2013 09:10 PM
19fifty4
Jul 10, 2010 01:54 PM
