cold starting trouble
Old Feb 26, 2004 | 10:09 PM
Fordtruckfarmerguy's Avatar
Fordtruckfarmerguy
I have a 2001 f-150 with the 5.4, 60,000 miles. When it is cold,(the engine, and air temp below 45) I have to hold gas pedal to get this engine to run. It will crank up, rev to about 1000 rpm and then cut off, will not run until gas pedal is held for about 3-5 seconds. once the engine warms up no more problems, has happened occasionaly since november, but has started to occur almost every time cold starting. No service codes. Any ideas?????
Old Feb 27, 2004 | 09:44 AM
LxMan1's Avatar
LxMan1
Welcome to FTE
I would replace the IAC (Idle Air Control). It is located on the rear side of the throttlebody elbow.
One that is sticking will act worse in cold weather.
Jimmy
Old Mar 4, 2004 | 07:42 PM
kenrobert's Avatar
kenrobert
Question cold start
Did this work I am having the same problem with my 97 4.6 liter. A machanic (whom i trust) told me it was lose timing chains. I would rather change a module than a chain.
Old Mar 6, 2004 | 09:52 PM
lallen1's Avatar
lallen1
Cam and crank position sensors will also cause the same thing.
Old Mar 6, 2004 | 11:39 PM
gkbid's Avatar
gkbid
I agree with Jimmy. Have read lot's of threads with 5.4's that wouldn't want to idle due to worn out IAC.
Old Mar 7, 2004 | 11:19 AM
SMiller's Avatar
SMiller
It's almost always the IAC, very commen on the 4.6s and 5.4s not that big of a deal.
Old Mar 10, 2004 | 02:20 AM
FordLariat's Avatar
FordLariat
Yeah, the IAC is definitely what to check on that. Tap it lightly when it starts acting up, see if this helps. Cleaning it will make it last a little longer, but you may as well replace it at the next available opportunity.
Ak68F250
Oct 15, 2008 09:31 PM
MPDano
Escape & Escape Hybrid
Oct 31, 2006 11:37 AM
woodrock03
Nov 3, 2003 04:58 PM
Jofrso
1983 - 2012 Ranger & B-Series
Apr 1, 2003 08:42 PM
PATS2002
Jan 27, 2003 08:35 PM
