Can someone please help me, I would like to know what size door speakers I have in my 92 F-150 5.0L, before I pull the panels off, as I have blown them, so they need replaced!! thank you!!!
of course you may ask, i have a 1000watt sony xplode amp and 1100 watt 10" subwoofer, so I figured
i'd go with the 6.5inch sony explode 180 watt door speakers
Originally posted by chefod Can someone please help me, I would like to know what size door speakers I have in my 92 F-150 5.0L, before I pull the panels off, as I have blown them, so they need replaced!! thank you!!!
I just replaced the door speakers in my 91 E-van and they were 6.5" round speakers. On a hunch, I stopped by our local K40 to see if they had a cheap set of speakers I could use and wound up buying a set of Ford OEM speakers with wiring harness still in the box for $15.95.
Originally posted by 94Bronco58 ouch! OEM speakers, no offense, but for speakers aftermarket is by far better, unless you are really easy on them, then I guess its appropriate!
If this was my main vehicle, I'd consider aftermarket speakers, but this is a winter beater/tow vehicle that I bought for $795.
Come springtime, I'll have my 94Z28 with its Bose/Monsoon stereo system trying to drown out a loud 4" exhaust. I also have a 99 Neon that my son's borrowing over the winter so that he doesn't have to drive his 94Z28 in the snow either.
Originally posted by 94Bronco58 Z28?? sounds Chevy to me!
Yeah, good for a vehicle that you don't drive all the time
You wouldn't want to drive mine all year round. A 396 Stroker, hooked to a TH400 with manual valve body and 4000 stall torque convertor passing to a 4.10 rear is a challenge to drive on wet roads let alone snowy ones. And with all of the salt that they dump on the roads in Michigan, I would be able to "hear" my car rusting out.
Oh, that and 8mpg on Super Unleaded gas. It's definitely NOT a daily driver.
