Sponsored by: Innova
speaker specifications
Old Oct 10, 2002 | 12:58 PM
greymule's Avatar
greymule
Post speaker specifications
I have a stock am/fm cassett with two 6" door panel speakers.
The speakers say premium sound on the back. What watt, ohm & ounze are these speakers? What is the output of the radio? Will two way speakers be OK to replace the stock speakers?
Old Oct 10, 2002 | 05:42 PM
optikal illushun's Avatar
optikal illushun
[updated:LAST EDITED ON 10-Oct-02 AT 06:45 PM (EST)]what yr and what make is it? i believe the premium has an amp and it rated 40x4 and the speakers amount to a good paper weight...almost all car speakers are 4ohms and 2-way or coaxels are good, but try to look for a good set of 3-ways.
Old Oct 11, 2002 | 01:21 AM
charlez's Avatar
charlez
Old Oct 11, 2002 | 07:50 AM
greymule's Avatar
greymule
I don't have a clue what is meant by 40X4.
Please explain. The vehicle is a '89 Ford F-150 Custom.
Old Oct 11, 2002 | 08:26 AM
John8172's Avatar
John8172
40x4 is 40 watts by (x) 4 channels. The amp has 4 channels, each one puts out 40 watts. Each speaker receives 40 watts...
Old Oct 11, 2002 | 09:48 AM
greymule's Avatar
greymule
I can use up to 4 speakers, 40 watts each? Great! What does bridge or bridgeing mean?
Thanks for the info
Old Oct 11, 2002 | 01:42 PM
optikal illushun
1st off u need an amp that is bridgable. it will usually say so on the box, specs, etc. all u do is tkae on positive from on side or channel and a negative from the other. u can then get more output from the amp.
1954_NJ_F100
Apr 12, 2016 03:02 PM
89BlueBronco
1978 - 1996 Big Bronco
Mar 14, 2012 08:22 PM
tractorfan
19
Oct 14, 2008 10:12 PM
FitchBanjos
15
Mar 11, 2008 11:15 PM
Vampiro
Jul 12, 2002 02:45 PM
