Offroad & 4x4
Tire selection question
Old Mar 10, 2004 | 07:21 AM
  #91
Busa01's Avatar
Busa01
That's where I got my SSR's, from 4wheelparts. Do you think a company of that size would sell me factory seconds? This was the first time I've ever bought anything from them. They ARE pretty good with warrenteeing stuff though.
tom
Old Mar 11, 2004 | 06:35 AM
  #92
ncl's Avatar
ncl
Well you'll never know but maybe they got factory seconds from their supplier without knowing it too so it could be a long line of errors.
Old Mar 11, 2004 | 07:46 AM
  #93
Busa01's Avatar
Busa01
Well, seeing that 4wheelparts is the BIGGEST wholesale/retail distributor in the US and is owned by ProComp, I would imagine that they would get better quality product than some of the smaller guys, but like you said anything could of happened.
I'm supposed to get those tires today, so we'll see if this fixes the problem. If it does, I'll take back all the bad stuff I said about swampers.
Tom
Old Mar 11, 2004 | 08:24 AM
  #94
BandBFord's Avatar
BandBFord
For those hard to balance large tires, try this! It has been used by OTR trucks for sometime...
http://www.4wheelpartsadventures.com..._tech01_01.asp
http://imiproducts.com/imi_htmlcode/.../imi_equa.html
http://www.kcdiy.com/AutomediaConten...01rt/main2.htm
Old Mar 11, 2004 | 08:53 AM
  #95
Busa01's Avatar
Busa01
nah, doesn't work. Problem is that it does not work well on tires that are deflated and inflated frequently because it clogs the schrader valve. And the problem with my two defective tires is that they are out of round, not just out of balance. 4wheelparts was pretty good about warrantying them so far. They will UPS Call Tag the bad ones once I have the new ones switched out. Hopefully, this will finally solve my problem and I can take "tire nightmares" off of my signature line.
Plus, the sand that you put in your tires is only good for a few ounces. When your tire needs a 5 pound dumbell duck-taped to the inside of the wheel just to balance it, there is nothing you can do except send the tire back.
Tom
Old Mar 11, 2004 | 09:28 AM
  #96
BandBFord's Avatar
BandBFord
You are correct, changing the pressures frequently doesn't suit Equal well. Weight is limited also. Works great for vehicles that spend alot of time on the road and minimal off.
rhodeisland350
Aug 30, 2008 08:01 AM
texcan
Nov 4, 2007 06:56 AM
oneofakind97
Offroad & 4x4
Jul 26, 2007 07:55 PM
dageabse
Aerostar
Oct 30, 2004 06:21 PM
chadrock
Apr 5, 2002 08:19 AM
