Offroad & 4x4
Tire selection question
Old Mar 3, 2004 | 07:30 AM
  #61
Busa01's Avatar
Busa01
What's a "Shanked" nut?
I'm having the wheels installed as i'm typing this.
Thanks,
Tom
Old Mar 3, 2004 | 07:50 AM
  #62
fishmanndotcom's Avatar
fishmanndotcom
http://www.mcgard.com/deutschland/en...flachsitz.html
those, I believe, are what he is talking about!
-jason-
Old Mar 3, 2004 | 07:53 AM
  #63
Busa01's Avatar
Busa01
Oh, ok. Those are for hubcentric wheels, not lugcentric. Which is ACTUALLY what my wheel is supposed to be. However, nobody makes a hubcentric wheel for my truck, except in stock form, which wouldn't allow me to run larger tires because of the 5 3/4 backspacing.
Thanks
Tom
Old Mar 3, 2004 | 07:55 AM
  #64
Busa01's Avatar
Busa01
Fishman
Do you play ??
Fishman.com, your username, is a musicians website, right??
Old Mar 3, 2004 | 07:56 AM
  #65
fishmanndotcom
i'm curious what exactly is the difference b/t hubcentric and lugcentric? the wheel centers itself on the lug nut on a lugcentric?
-jason-
Old Mar 3, 2004 | 08:03 AM
  #66
Busa01's Avatar
Busa01
Hubcentric is when the wheel is designed to be centered on the hub and not the lug. My stock rims have slotted lug holes so the rim can be slight rotated back and forth before tightening the lugs. The lug nuts are shanked. However, the bore in the wheel fits snuggly on the hub and this is what centers the wheel. It has been determined that you get a better center from this setup and all new vehicles are designed this way.
The old days everything was lugcentric, whereas one would use conical shaped lugs to center the rim lug holes onto the vehicle. Although this works ok, in many cases the lug nuts dont center the rim "exactly" onto the lug. Furthermore, if the lug gets bent, even slightly, in any direction, this will throw off the center bore of the rim. That's why they went to hubcentric wheel setups. It's much more accurate and can allow for the lugs to be inadvertently bent "accidentally" without affecting the centering of the wheel.
Tom
Old Mar 3, 2004 | 08:05 AM
  #67
fishmanndotcom
ooooooooooooooooooooooooooo....ok
cool thanx....learn something new everyday
-jason-
Old Mar 3, 2004 | 09:22 AM
  #68
wick246's Avatar
wick246
So did the new wheels fix the problem???
Old Mar 3, 2004 | 09:29 AM
  #69
Busa01's Avatar
Busa01
I haven't picked it up yet. Probably at lunch time I will. I've got my fingers crossed. I'm sure it WILL make a difference. May not fix it all together but I'm sure that the Mickeys are more precisionally machined than the stamped and welded rock crawlers. I'll let you guys know in a few hours. The anticipation is tearing me up !!!!
Old Mar 3, 2004 | 01:47 PM
  #70
Busa01's Avatar
Busa01
OK EVERYONE.
THAT WAS THE PROBLEM....THE ROCK CRAWLER RIMS.
I JUST PICKED UP MY TRUCK WITH THE NEW MICKEY THOMPSON WHEELS AND TOOK IT UP TO 75MPH AND SMOOTH AS GLASS (WELL, AS SMOOTH AS A SWAMPER CAN GET)...
VERY HAPPY. AND THE RIMS LOOK GREAT.
TOM
Old Mar 3, 2004 | 02:22 PM
  #71
wick246's Avatar
wick246
Good news.
When you get a chance post some pics of the new rims.
Glad it finally worked out.
Old Mar 3, 2004 | 02:29 PM
  #72
Busa01's Avatar
Busa01
Yes, this thread has been great!!!!
I'm going to update my User's gallery in the next few days.
Thanks again,
Tom
Old Mar 3, 2004 | 03:53 PM
  #73
nick88f150's Avatar
nick88f150
....guess i wont be buying rock crawlers with my trxus's like i originally planned. anyone know if american racing rims are stamped steel too, or if they are better quality?
Old Mar 3, 2004 | 04:03 PM
  #74
Busa01's Avatar
Busa01
Don't get the crawlers if you plan on highway driving in speeds excess of 60 mph......but, who knows, maybe I just got a bad set. But, I can see when I take them off and put them on that the lug holes are cheaply drilled, not completely round and generally look low quality. But, then again, they're only 60 bucks. Get what you pay for I guess. I don't know anything about the American Racing rims.
Tom
Old Mar 3, 2004 | 04:19 PM
  #75
nick88f150's Avatar
nick88f150
yeah, thats what i figured, i guess ill be spending a bit more on my wheels, since i do lots of high-speed on-road driving
