Standard 4-Speed Converted to Automatic
Old Feb 24, 2004 | 08:31 PM
65JohnnyF260's Avatar
65JohnnyF260
Question Standard 4-Speed Converted to Automatic
Hey i need help!!! Im looking at a 1965 Ford F-260 4x4 w/ a 352FE motor 4-speed on the floor. My question is how much would it cost to get some power steering in it, as well as how much a 4-speed standard on the floor to an automatic would cost approximately. I wouldnt want anything fancy just the simple stuff. Thanks a bunch!!!!
Old Feb 25, 2004 | 12:08 AM
Putt's Avatar
Putt
The power steering would be hard I believe. Ford used a linkage assist system with a power cylinder and control valve until sometime in the mid to late 70's. It is not an easy system to transplant. You might be able to find a later power gearbox that will fit, but would need to check compatibilty with your linkage. The auto swap should be easier if you can find a 4x C6 auto. Do you have the divorced transfer case?
ultimatereality5
Mar 18, 2007 05:01 PM
Redneck1016
Nov 29, 2005 01:59 PM
260falcon
Nov 8, 2005 10:01 PM
ssKable
Jul 25, 2003 01:02 PM
rangersvt04
Jun 4, 2003 12:22 PM
