Or something plugging up the oil pump pickup screen. When the pump would try to suck up more oil than it could it would starve for oil and result in pressure drop. Put a direct reading guage on there to be sure.
Not sure what year truck you have but if you have the variable pressure sender you can test it with a swing meter type ohm meter and an aircompressor blow gun. Remove the sender, hook up the leads to the sender. (Alligator clips make this easier) Now use the blow gun to simulate oil pressure. Use safety glasses as a little oil will try to get in your eyes. As you increase air pressure into the sender you should see the needle deflection change just as the guage needle does on the dash.
And I guess the same test would work with the cheesie pressure switch. No pressure (Basically switched off) Pressure above just six or seven pounds (Switched ON) and you should get full needle deflection.
i got the pan off.thank you GOD.it was a real pain.i think pulling the motor would have been easier.could not tell much looking at pump but rods and mains seemed ok no metal particles were visible in the pan.went ahead got meling high volume pump & new tube.didnt get it in wont be here till tomorrow.i will update yall when finished.thanks for help!
High volume oil pump is not nessessary. The stock pump should more than be able to handle the job.
Did you pull ALL the rod and main caps to check the bearing condition ? I would hate to see you put it all back together and still have one bad bearing.
Another possibility: Somewhere I read that worn rod bearings will throw oil by centrifigul force. Consequently, as RPMs go up, oil pressure goes down. Worn mains are consistently low throughout the RPM range.
i got it on today.idled around 55psi went back together alot easier.i know i should have taken all the caps and mains off but this is probably temporary. i plan in the next year to replace the whole nine yards.not sure which to do rebuild(already once with previous owner)or go with remanufactured.any one know what a factory new 300 goes for? not sure which route to go.
