1978 - 1996 Big Bronco
Ball Joints
Old Jan 25, 2004 | 12:27 PM
BillyBob69's Avatar
BillyBob69
Oh I'll say it was quite a job. But now that I know exactly what it takes it would probably only take me half a day including the trip to the machine shop. But fair warning....don't bother with the ball joint press you rent from Autozone. IT REALLY SUCKS! I have used em on the 2wd vehicals, but they don't fit the larger 4x4 steering knuckles. But DO....use at least a 3 or 4 lb sledge for the pickle fork. If you use a regular hammer it will work but add about 2 hrs on to the job each side. I borrowed a 12 lb sledge from a neighbor and only took 6 hits to drop the knuckle on the left side. the right side took about 2 hours with a standard hammer and I was gettin mean with it.
Old Jan 25, 2004 | 12:45 PM
wsigo's Avatar
wsigo
Yep that's why you just get a ball joint seperator for the air chisel/hammer like I got! Sure makes life a lot easier!
Old Jan 25, 2004 | 08:35 PM
screwy's Avatar
screwy
Weird, I could pull and press new ball joints in a knuckle in 10 minutes with AutoZone’s press. Granted once I figured the stupid thing out
Old Jan 25, 2004 | 09:15 PM
johnb268's Avatar
johnb268
yea i had no problems with the autozone press either, i even used it when i replaced the axle shaft joints made life really easy and didn't cost a dime in the end
bremen242's Avatar
bremen242
I was going to buy one of those air chisel things. however, I didn't have a compressor yet
Old Jan 25, 2004 | 09:25 PM
BillyBob69's Avatar
BillyBob69
Well then maybe you got a larger one than I did...cause what I had...wouldnt fit with the receiver cup. Ah well...its done...no biggie.
carbpower1978
Feb 14, 2012 01:12 PM
Tony79shortbed
Aug 24, 2011 12:47 PM
rb21747
Dec 3, 2009 02:46 PM
jdk9261982
Sep 24, 2005 03:27 PM
