waste gate sticking
Old Jan 11, 2004 | 07:31 AM
rckrwlr's Avatar
rckrwlr
waste gate sticking
ever sence I installed the super tuner to my truck the waste gate will open when the truck shifts. usualy when I'm getting on the highway. now the waste gate is opening and staying open but only when the engine is starting to warm up. I figure I need to tow something heavy up a steep grade and clear out any gunk. Anyone have any ideas???
the truck has 125k on it and I have never had a vehicle with that many miles on it. so i'm getting a little woried.
Old Jan 11, 2004 | 08:05 AM
rckrwlr's Avatar
rckrwlr
After doing sone reading some of the thread I think it might be my EBPV but I have never herd it befor I figured it was the waste gate. at what temps will it operate
Old Jan 11, 2004 | 03:56 PM
ltfox's Avatar
ltfox
Question: Is the wastegate and the EBPV the same thing????
Old Jan 11, 2004 | 04:05 PM
BenRosey's Avatar
BenRosey
As far as I know, those are the same thing.
Old Jan 11, 2004 | 09:31 PM
Bob Goodsell's Avatar
Bob Goodsell
Lightbulb Waste Gate vs EBPV
The waste gate and the EBPV ARE NOT the same thing.
The EBPV closes when the engine temp is low, such as start up. The waste gate opens when there is to much boost pressure. Both may be on the turbo but do different things.
Bob
Old Jan 11, 2004 | 09:35 PM
ltfox's Avatar
ltfox
Thanks for the info Bob. Do all PSD have a wastegate or is that a addition you have to install afterwards?
Old Jan 11, 2004 | 09:45 PM
Bob Goodsell
All SuperDuty's (99 and up) have a waste gate. Earler PSD's did not. The EBPV is on all PSD's with the cold weather package, which is most of them.
Bob
Old Jan 12, 2004 | 01:42 PM
bricot's Avatar
bricot
I've noticed my EBPV valve staying open as well, even after the temps are up in the 'useable' range. I was at a stop light and it was active, so I decided to try a shut down and restart.... and after I restarted it, the valve was no longer engaged ....
Old Jan 12, 2004 | 04:42 PM
ltfox's Avatar
ltfox
Last winter I could hear my EBPV working like it should. But this winter I have'nt noticed it working. Is their anything I can check??
Old Jan 12, 2004 | 08:26 PM
fast freddie's Avatar
fast freddie
I'm a little confused (not unusual for me). I have a 95 PSD and there is some kind of linkage going to the turbo that appears to operate an internal mechanism (a valve I would assume). What is this?
Old Jan 12, 2004 | 09:23 PM
DCClark's Avatar
DCClark
It opens a butterfly valve
The mechanism looks like a butterfly. I will post a picture of it tomorrow at work, we removed the portion of the turbo that has the butterfly in it and replaced it with a banks power elbow. The question I have is now that we did that the actual actuating rod for that just dangles around in-side (still attached to the linkage) the housing, does that hurt anything? In the banks instructions it never said anything about removal the rod.
Old Jan 12, 2004 | 09:29 PM
ltfox's Avatar
ltfox
The mechanism is your exaust back pressure valve(EBPV). It is a butterfly valve as descibed above that closes when your truck is cold to help your diesel warm up.
Old Jan 12, 2004 | 10:21 PM
fast freddie
Thanks......
Old Jan 14, 2004 | 10:54 AM
DCClark's Avatar
DCClark
As promised here is the pictures
Turbo Side of housing + EBPV
Front Side of housing + EBPV
Old Jan 14, 2004 | 04:28 PM
fast freddie
Excelllent PICS. Thanks. I assume that the lever is actuated by some type of temp sensing devise?
lartross
Aug 11, 2012 03:38 PM
gumper 123
Jul 31, 2011 10:06 PM
BOB D
35
Feb 3, 2011 07:11 AM
gunnar7.3-9
Dec 24, 2009 07:18 AM
bigbubba87
13
Feb 7, 2009 10:04 PM
