diesel warm up
Old Jan 13, 2004 | 09:03 AM
fordblue_ca's Avatar
fordblue_ca
diesel warm up
I'm looking to buy a 2001 psd and was wondering how long should you let them warm up before you drive and are they ok for daily shorter trips like 15mins??
Thanks
Joey
Old Jan 13, 2004 | 09:20 AM
fordblue_ca
Please reply with you thoughts ASAP as I have to make up my mind today! yikes! LOL
Old Jan 13, 2004 | 09:49 AM
Johnboy60's Avatar
Johnboy60
I have no idea as to the short trips in your area, because of the temps, but I use mine for some short trips. I will once in awhile just take it out on the interstate and run for 30 mins to get everything hot and moisture out of engine. I keep my plugged in for 3 hours before I need the truck and I usually let it idle till the fast idle kicks in, and then I leave but I take it easy until the temp guage is up. However take this into account, I am early retired and I am in no big hurry to get anywhere.
Old Jan 13, 2004 | 10:13 AM
BluesManF250's Avatar
BluesManF250
You really only need to let it warm up a couple of minutes before pulling away. It's better to warm it up while driving. Just take it easy until your gauge is in the warm area and then you will be fine. Diesels like to be run, but 15 mins. runs are OK, just keep up with the maintenance. I live between to cities that are a 15-20 mins drive either way. My truck has 33k on it and runs like a champ! We do take it on trips, of 1-3 hrs. on a fairly regular basis and she gets up to 20.5 mpg on those longer trips.
I say go for it, but really check the thing out or have a mechanic check it out for you. Good luck!
Old Jan 13, 2004 | 10:42 AM
Cool Canuck's Avatar
Cool Canuck
Re: diesel warm up
Thanks
Joey
I have an 01 that is my daily drive. Trip to work is 5 minutes. (5 Km). I don't let it warm up usually unless it is below -30 C. (I'm in Winnipeg) Just keep it around 1500 RPM until the temp registers and below 2000 RPM until in operating range. Short driving like this comes under Severe Duty Use, so change oil often.
Old Jan 13, 2004 | 02:23 PM
fordblue_ca
Thanks Guy's for you help, I have them working on the financial end of things right now, wish me luck! I will know by the end of today!.
Thanks
Joey
Old Jan 13, 2004 | 03:39 PM
elkslayer1's Avatar
elkslayer1
Fordblue, mine is an 00' and when it is cold 20 degrees or less i let it warm up for 5 to ten min, especially when it is below zero, remember to plug in. going on 4 years w/100,000 miles and runs like a champ! My truck is an every day truck so 5 min to five hours not unusual, drive like you would any vehicle and enjoy. If you are driving the freeway any period of time at speeds of 70 mph or more, it wouldn't hurt to let your truck idle for about 5 min when you get to your destination to give your turbo a chance to cool down. Just my .02 cents. enjoy
Old Jan 13, 2004 | 09:36 PM
Fordman4x4's Avatar
Fordman4x4
I'm assuming your talking about warm up mostly in the winter...
I usually give my truck 5-20mins depending on the temps outside. I have a remote starter and I would highly recommend one, It's so nice to have in the winter.
Keep in mine the PSD will not fully warm up to normal operating temps untill you drive it on the road, especially in the winter cold...
Nelson
Old Jan 14, 2004 | 06:47 AM
powerstroker250's Avatar
powerstroker250
Yep, change it every 3000 miles.
Old Jan 14, 2004 | 05:08 PM
Oklahoma's Avatar
Oklahoma
Lots of short drives on a gas engine craps out the exhaust pipe (condensate) and engine. It won't be long before the gasser starts using oil since it is not operating around optimum temps for long. Just FYI, don't know how it effects the diesel engine. Expected the same? Nobody mentioned it for the diesel so maybe not. Before you drive the short trips a lot, do a search for this.
Congrats and good luck on psd purchasing. Best thing I ever done.
Old Jan 14, 2004 | 05:18 PM
fordblue_ca
Bought the truck!! couldn't be happier! I love the sound of that diesel and turbo!!!
Thanks for all your info everyone!
Joey
Old Jan 14, 2004 | 05:44 PM
F0rdF0rever's Avatar
F0rdF0rever
Congrats on your new truck Joey. This forum is great and it well answer any questions that you have about your truck.
Good luck with your truck.
Steve
4griffins
39
Sep 11, 2013 03:35 AM
mwkobe
Aug 31, 2011 08:15 PM
KonaGrown
49
Apr 1, 2009 10:18 PM
wildstang
17
Jan 27, 2006 09:03 PM
352 blue
13
Nov 22, 2004 02:32 AM
