Breathing oil?
Old Jan 7, 2004 | 11:09 AM
wfodickinson's Avatar
wfodickinson
Breathing oil?
The intake on my PSD is drawing oil out of the valve cover breather and in to the turbo. Any thoughts?
Old Jan 7, 2004 | 11:36 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep, it sure is. Designed that way.
Mine dosen't
Old Jan 7, 2004 | 11:50 AM
wfodickinson
Seems to be taking in alot more than should be necessary. Oil is leaking out of the boots that connect to the intake runners.
Seems a bit silly, even for a Ford.
Old Jan 7, 2004 | 01:45 PM
wfodickinson
Anyone at all.....................Bueller.................Bu eller............................................. ......................Bueller?
Old Jan 7, 2004 | 05:04 PM
International Tech's Avatar
International Tech
That is normal unless its actually running down your pipes. Clean them off and crank her up, if its a blowby or turbo problem youll know right away but i dont think it is. I think its just the breather sucking oil into the intake.
Old Jan 7, 2004 | 06:50 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yes, it's rediculous. That is why many of us have rerouted the line to not vent into the intake.
alanscott: can you edit some of the ...... out of his last post so it fits on the screen?
Old Jan 7, 2004 | 09:51 PM
f350xlt460's Avatar
f350xlt460
so you guys mean that this leak that i have is "normal"?
Its sucking in oil in the intake.
How would i reroute the oil breather??
Old Jan 8, 2004 | 11:24 AM
cookie88's Avatar
cookie88
FTE Emeritus
Well, if it's been cooking on there for four years then yeah, that would be normal.
There are lots of variations on the reroute. Do a search on CCV mod.
On mine I just removed the vent hose to the intake, turned the crankcase vent on the valvecover 180* (so it faces rearward) and ran about 10' of 3/4" hose up over the master cylinder and down the frame dumping out under the bed of the truck.
Old Jan 8, 2004 | 12:46 PM
wfodickinson
My PSD leaks enough oil on the floor without giving it one more hole to leak out of.
Old Jan 8, 2004 | 08:34 PM
cookie88's Avatar
cookie88
FTE Emeritus
It dosen't drip, just smokes a little bit. It's exactly the same as a draft tube (or road tube) on a big rig.
Old Jan 8, 2004 | 09:44 PM
mueckster's Avatar
mueckster
The only problem I see doing this mod is the chance it may not pass a visual inspection of emission control devices during state safety inspections in some areas. Some states or counties are lacks about this, some are pretty strict.
Old Jan 8, 2004 | 11:00 PM
f350xlt460's Avatar
f350xlt460
I do a search for CCV mod and end up with nothing on this site. Cookie88, do you have any pics of yours?
It sounds prety simple to do, just got to pull apart intake again and route some hoses i guess
wheelerg
Feb 2, 2014 12:14 PM
jakegypsum
Oct 3, 2009 11:07 AM
pr
Mar 10, 2002 06:32 PM
fordmandan
Modular V8 (4.6L, 5.4L)
Jan 13, 2002 07:51 PM
tscaud
Dec 18, 2001 11:13 PM
