2000 EB Expy running board lights
Old Jan 7, 2004 | 08:58 AM
tplanz's Avatar
tplanz
Question 2000 EB Expy running board lights
I have recently noticed that my running board lights come on for what appears to be no apparent reason. This happens when the truck is locked. They don't always stay on either. The other day after the truck sat for two days without being run, I found the battery to be dead. Was wondering if anyone else has seen this before and if so what could be the cause.
Old Jan 7, 2004 | 09:58 AM
MisterCMK's Avatar
MisterCMK
It sounds like there is a short somewhere that is causing this. Check your door latches, and lube them up.
Old Jan 7, 2004 | 10:01 AM
tplanz's Avatar
tplanz
Not to sound ignorant, but what would the door latches have to do with it. Just curious.
Old Jan 7, 2004 | 11:20 AM
FarmLaw's Avatar
FarmLaw
On older cars, there used to be a spring-loaded switch that controlled the dome lights...when the door opened, the dome lights would come on. When the door closed, it would press on the switch and the dome lights would go off.
On a lot of newer Fords (Expys and Rangers come to mind) the dome lights (and hence, the running board lights) are controlled by several things, including use of keyless entry remotes and the door latches. Rather than using separate switches, the door latches have a switch built into (or on) them that signals when the doors are open (and hence when the lights should be on). These are notorious for sticking. A good shot of WD40 up into the latch area helps a great deal.
If this was the problem, I'd expect that the dome lights would also be staying on...and I thought Expys had a limiting switch that shut off all of the courtesy lights after 45 minutes or an hour or something to prevent battery death...
But it's a good spot to start.
Old Jan 7, 2004 | 11:42 AM
tplanz's Avatar
tplanz
Hey Farmlaw, That makes sense to me now. I'll give it a try. However, I think it might be something else as the lights will just come on for no apparent reason and then go back off for no apparent reason. Thanks for the help.
Old Jan 7, 2004 | 06:28 PM
BigMan69's Avatar
BigMan69
As for the WD40 trick, if I am correct, you must blast the WD40 upwards on the drivers side and downwards on the passenger side.
BigMan69
Old Jan 8, 2004 | 07:41 AM
FarmLaw's Avatar
FarmLaw
Is it just the running board lights, or is it the dome lights too?
The door trick would only work if it was both running board and dome lights--as both illuminate when the door is opened.
If it is just the running board lights, then the problem is elsewhere.
Pete0415
Jan 4, 2015 06:43 PM
lvgto
Mar 13, 2007 07:55 PM
NorCalBusa
Mar 4, 2007 10:04 AM
blahboo
May 30, 2006 08:59 AM
ugotkern
Aug 23, 2005 06:51 AM
