Sponsored by: Real Truck
Running board/dome light
Old Mar 3, 2007 | 02:41 PM
NorCalBusa's Avatar
NorCalBusa
My truck didn't come with factory running boards, so I got some Westin's as indicated on this site (thanks). I did a search here- but can't find a thread that indicates where to grab the dome light- so the running board light comes on with the keyless entry or the door opening (dome light comes on with either).
Where and what color do I grab that? Westin's directions indicated it might be underneath "somewhere". Thanks.
John
(Cool forum by the way!)
Old Mar 3, 2007 | 02:48 PM
Green_Dually's Avatar
Green_Dually
What year truck?
Old Mar 3, 2007 | 02:49 PM
NorCalBusa's Avatar
NorCalBusa
2007 F250 SD, Crew
Old Mar 3, 2007 | 02:53 PM
Green_Dually
Well in my 03,i tapped into the wire near the bottom of the door.(not on the door,but on the truck).Theres a plastic piece that just pulls off(up).I took a test light to find the right wire.
But i took power from the batt,to a relay.I just used the wire as a trip wire to activate the relay.
Old Mar 3, 2007 | 02:58 PM
NorCalBusa's Avatar
NorCalBusa
So that wire below the door went hot with the dome light? I'll go check and report back- thanks!
Old Mar 3, 2007 | 03:00 PM
Green_Dually
yes the wire went hot when dome light went on.Off when dome light goes off.It will have a delay in going off,just like the dome light.
Old Mar 3, 2007 | 03:02 PM
NorCalBusa's Avatar
NorCalBusa
Passenger or driver side? Thanks again!
Old Mar 3, 2007 | 03:04 PM
Green_Dually
It was the drivers side in my truck.
Old Mar 3, 2007 | 03:11 PM
NorCalBusa's Avatar
NorCalBusa
I'll go check
Old Mar 3, 2007 | 03:43 PM
NorCalBusa's Avatar
NorCalBusa
Nothing underneath the chassis- except a large bundle going to the back of the truck.
Under the door sill (inside the cab, the sill you would step on to get in), removed the plastic sill there are about 10 wires in the tray running the length of the cab. I didn't ID any that came on/off with dome light- but did find two that were hot all the time. Its a tough to prob them with the door closed with my fat butt...
Old Mar 3, 2007 | 03:58 PM
Green_Dually
There is a wire there that will lite up with door open and off when door closed.Again i could look at mine and tell you what color wire,but not the same year.So the wire might not be the same color.
I found the fuse for the dome lights,then went and probed.When i found a hot one,i pulled the fuse.
When i found the wire that did that,i put the fuse back in,and left the door open.The GEM will turn off the dome light after a little while.If the test light goes out then thats your wire.
The wire isnt under the truck,it right under the panel,where you step to get in the truck,on the drivers side.
Old Mar 3, 2007 | 04:30 PM
NorCalBusa's Avatar
NorCalBusa
Bingo- found it. It is right where you said; in the cable run inside the door sill*; 18 gauge Black with a Blue stripe.
*open the driver door. Remove the plastic cover that goes over the threshold, right where the weatherstrip meets the carpet. Under that is a trough, that has a large cable bundle. It divides at the driver's seat, some going to the seat, the rest going aft. In the aft bundle is where the Black/Blue wire is.
I feel like I contributed- but you had the where!
Keywords: dome light running board step
Old Mar 3, 2007 | 06:03 PM
Green_Dually
Glad i could help.
Old Mar 4, 2007 | 10:04 AM
NorCalBusa's Avatar
NorCalBusa
Pics added;
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 8, 2017 05:24 AM
carid
Jan 3, 2017 07:52 AM
carid
Sep 8, 2016 07:21 AM
randella
Nov 12, 2015 08:34 PM
LadyDi
Jul 9, 2015 03:33 AM
