Difference between injectors, old vs. new
Old Jan 8, 2004 | 08:14 AM
  #46
"Luke" SdeS's Avatar
"Luke" SdeS
Fm jorzac
Went in later to talk to the tech who informed me there is nothing wrong with it. He said the oil level was normal and there was no cause to investigate any further...
I bet he would not put that in writing & on a service report....
BTW, why not tell us the name of this Dealer ????? There is nothing wrong with this---they should be responsible for what they say..
Old Jan 8, 2004 | 09:52 AM
  #47
emtabmm's Avatar
emtabmm
ain't that the truth. Why won't dealers be responsible for their actions? I know that is an open ended question and I don't own one of these trucks, but I would be screaming my head off at these dealers for not taking action. My mgr have gone a round or two over my Sable, don't settle for less than excellent service!!!
Old Jan 8, 2004 | 10:02 AM
  #48
Hjudge49's Avatar
Hjudge49
It really comes down to the Dealer. I think if my injectors fail, my dealer will probably replace them all. I have had excellent service from my earlier problems, and the service tech even told me about the leaking rear pinion seal before I noticed it. I have to drive about 55 miles to get there, right past my local dealer who is 2 miles from my office, but it's worth the effort.
Old Jan 8, 2004 | 10:15 AM
  #49
cdtruckn's Avatar
cdtruckn
You know, It's in the dealers advantage to find and fix all the truck problem's that the customer complains about, (I just don't under stand) Thank goodness for my dealer thy listen and explain About any thing I cry about.
Old Jan 8, 2004 | 10:23 AM
  #50
riceburner's Avatar
riceburner
i apologize guys, i dont know the nerest ( INTERNATIONAL TRUCK DEALERSHIP ) around my area so i went to the shaker shop. no offencse international tech , but international dealers around here is closed!!!
Old Jan 8, 2004 | 10:24 AM
  #51
dhermesc's Avatar
dhermesc
Stupid question time.
Ford replaces only the leaking C94 injectors, do they replace with the C95 injectors? Has anyone studied the ramifications of running "mixed" injectors over a long period of time (assuming the rest of the C94s run a long period of time)? I know when working with tractors (diesels expected to run thousands of hours between mechanical services) injectors where replaced in groups not one at a time.
Old Jan 8, 2004 | 10:37 AM
  #52
Hjudge49's Avatar
Hjudge49
I don't think it will matter, The redisign is to the piston to keep the spring from binding and preventing it from closing completely, which makes the c94's leak. Otherwise they should put out fuel in the same manner and amount.
Old Jan 8, 2004 | 10:38 AM
  #53
cdtruckn's Avatar
cdtruckn
Not stupid.
thy are the same just a spring retainer update.
Old Jan 8, 2004 | 12:17 PM
  #54
jorzac's Avatar
jorzac
TO EMTABMM-
Can not e-mail yet. Have not been a user long enough. Can you e-mail me your email address. Also, service manager was standing there when the tech. said they were not going to check for injector failure. Have already purchased my oil sample kit and will get it done soon. Maybe i should just drive it until it locks up!!
Old Jan 8, 2004 | 01:16 PM
  #55
emtabmm's Avatar
emtabmm
Originally posted by jorzac
TO EMTABMM-
done
Old Jan 8, 2004 | 02:14 PM
  #56
jschira's Avatar
jschira
Ford changed the injectors again in the '04 engines. Not sure of the change. Maybe just a different coating, but there was a change.
BTW - Some posts about failed C95 injectors are starting to show up.
Old Jan 8, 2004 | 02:17 PM
  #57
jschira's Avatar
jschira
Actually, I believe that the redesign was to stop side loading of the plunger, which was causing scrapes or grooves in the plunger.
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
bigblockford_390
Testing.....
Sep 16, 2007 03:20 PM
