Difference between injectors, old vs. new
Old Jan 5, 2004 | 06:36 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally posted by International Tech
by pressurizing the system w/ air. Most of the time you see the leaking ones. Of ourse the valve covers are off. You can also use dye as well.
Labor intensive.........to test, and if you must do all that to test ............then how long to actually take the culprit out and replace........o-say for one?
10 miutes of 20 or...
remeber you have tested and now just to change one
Old Jan 5, 2004 | 07:39 PM
International Tech's Avatar
International Tech
not long at all
Old Jan 5, 2004 | 07:42 PM
International Tech
sorry about that, around 20-30 minutes. Forgot you have to remove the oil rail.
Old Jan 5, 2004 | 09:04 PM
aharleybe's Avatar
aharleybe
If you have to remove the oil rail to get to the injectors it seems like Ford could solve a lot of issues in the same area. Go in and replace all c94 injectors to reduce chance of fule leaks and reasemble using new style oil rails that would solve idle problems and after all that, they could give us are pilot injection back. Sounds simple right? FORD NEEDS TO RECALL ALL C94 INJECTORS!!!
Old Jan 5, 2004 | 09:09 PM
aharleybe's Avatar
aharleybe
fule???:-staun fuel sorry
Old Jan 5, 2004 | 09:45 PM
IB Tim's Avatar
IB Tim
PLEASE do not take this wrong.....how sure are you of these times, we both know were I am going with this. I am not questioning you knowledge, I just need to get this correct.
Would you say that 90% of time is in getting to....the injector it’s self… just to test for leaks and 10% to change each one.
This is incredibly important to have this clear.The analogy would be like the old small block Chevy, if you needed to change a lifter (and not go through the pushrod hole) you have got the intake off and all........you were sitting right in front of all 16...........then why not!!!
Old Jan 5, 2004 | 10:41 PM
International Tech
pretty sure seeing how as ive been underneath the valve covers of this engine(diff vehicles) several times.and was one of the 1st to go to Int'l engine school for this engine. Hardest part is getting to the injectors and the diagnosis. The driverside is the bigger of the PITA's because of the location of the ECM/IDM on Internationals and the Engineers just love making lives difficult for the techs. These injectors are easier to replace (once you get past the valve covers) than the 7.3 or T444E. The hold down bolts actually pulls injector up w/ it while you are loosening it. I have mixed emotions about the location of the Oil Rails. Its not hard at all to remove just more time consuming to replace the top o-rings on all injectors where oil rail sits on top of them just to remove one injector.
Old Jan 5, 2004 | 10:45 PM
IB Tim's Avatar
IB Tim
This is GREAT. do you agree with my % estimates
You knowledge is good for all on FTE
and Thanks again
Old Jan 5, 2004 | 10:47 PM
International Tech
yes. as long as you dont drop any bolts down the pushrod galleys.
I love this stuff. Your welcome
Old Jan 6, 2004 | 01:51 AM
riceburner's Avatar
riceburner
what is the best way to check if there is fuel in the oil? i know about the smell and over filling dip stick. my oil looks like there is a dye in it cause there is a funny looking applegreen color on it. i have 6.0psd X 02/03 build, kentaky plant.
Old Jan 6, 2004 | 06:39 AM
International Tech
those are basically the right ways too check for fuel in oil without sending off to a lab for testing. Im positive that if you are getting fuel in your oil you would definately notice it. BTW, that does sound like dye in your oil. Is that a brand new truck? If not, is Ford dealer checking for something?
Old Jan 6, 2004 | 07:49 AM
Hjudge49's Avatar
Hjudge49
Tim, this sounds like what i thought before: Once you get to the injectors themselves, the actual time to replace each on is minimal. FMC just doesn't want to bite the bullet and admit they have a problem. The actual cost to Ford to replace them all at once is probably less than replacing one, then having to go back and do it again if another fails.
Old Jan 6, 2004 | 07:57 AM
  #28
IB Tim's Avatar
IB Tim
You can count on it.
Old Jan 6, 2004 | 08:44 AM
  #29
"Luke" SdeS's Avatar
"Luke" SdeS
I keep reading the part about Ford Recalling all the injectors in dealer inventory, but I undestood that they didn't actually swap out the old for the new on the vehicles in dealer stock. ....
Now wouldn't that be an interesting legal argument to raise in challenging Ford's only willing to replace the bad ones.....
Old Jan 6, 2004 | 09:03 AM
  #30
aharleybe's Avatar
aharleybe
What really doesnt make sense is Fords willingness to repeatedly exposing our engines to internal damage by only replacing the c94 injectors that leak instead of doing them all while the engine is opened up. If you take your truck in for a leaky one how much harder could it be to change all at that point?
