Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
degreasing wand/gun
Old Dec 31, 2003 | 07:31 AM
gfe76's Avatar
gfe76
degreasing wand/gun
Trying to make a degreasing wand/gun to run off my compressor.(I know you can buy them but they are made poorly and don't hold up). I need to make 3 of them. I have one made but it will not siphon chemical from my gallon container on the ground. I have an 8 foot tube coming from the bottom of the 1/8" T fitting. I think the problem is the T fitting does not have a venturi that will cause the downtube to siphon. how do I solve this? Thnaks
Old Dec 31, 2003 | 09:38 AM
gasman6674's Avatar
gasman6674
Try putting an orifice in the chemical line. Air pressure rushing across it should create a pressure drop/siphon.
Hope this helps.
Old Dec 31, 2003 | 10:42 AM
gfe76's Avatar
gfe76
Put a smaller tube in the downspout fitting that screwed into the siphon part of T. it still does not siphon. Must be bcause the T does not have a venturi to increase air speed thereby decreasing pressure to set up vacuum for siphoning. I have been on internet all morning trying to find a T venturi that will work with air pressure to siphon liquid, but can't find anything. Seems such a simple fitting would be available somewhere.
Old Dec 31, 2003 | 06:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
I just bought a spray wand from a tool store, it was under $20.
Old Jan 1, 2004 | 12:34 AM
gfe76's Avatar
gfe76
What store? what was model #, complete description. Is the pickup tube down next to the air intake tube? Or, is it near the end of wand?
Old Jan 1, 2004 | 01:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
I wish I could show you a picture but my son has my camera in Houston at the moment. I don't have any packaging. The die cast (zinc) housing has an air inlet and liquid inlet hose barb on the "but" end. A length of plastic line came with the unit. It says Engine Cleaner on the side. There is a trigger button for air control and a volume control needle valve for the liquid. The actual liquid/air mixing occurs in an angled nozzle on the end of the 10" wand.
Harbor freight has a cheaper version:
http://www.harborfreight.com/cpi/cta...emnumber=37346
Northern tool has item number 452180
http://www.northerntool.com
Neither of these is as nice as the unit I have. I purchased it at a local tool store that sells compressors, automotive tools, SK hand tools, etc, mainly professional stuff.
I have had more luck with heavy engine grease with a pressure washer.
Old Jan 1, 2004 | 09:22 AM
gfe76's Avatar
gfe76
Thanks, I will look for one. I still wish I could find the right T with a venturi so I could build my own out of copper and brass fittings. It would be so so simple to make if yuou had a T with a venturi.
Old Jan 17, 2004 | 05:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
I just saw one in a new Cummins Tool store the other day. Item number 1117 costs $4.99 and is very similar to the one I have but I think mine was higher priced.
http://www.cumminstools.com/browse.cfm/4,28.html
Old Jan 19, 2004 | 12:32 PM
gfe76's Avatar
gfe76
thanks I;'ll check it out.
Knothole
Jul 7, 2012 11:58 AM
F250FarmBoy
Paint & Bodywork
Jun 21, 2007 10:13 PM
Pablo-UA
Aerostar
Apr 21, 2006 10:05 AM
Dutch123
1978 - 1996 Big Bronco
Oct 28, 2005 03:31 PM
