What cars and trucks fits a/c condensor of aero. I will install new a/c and I wand to sell parts of my old one.
The other quation: yesterday motor stalled tewice, but it runs well now, and i have stored codes 23, 86, 89. What is means? I can not understand why it stalled. I tried to start it and it started well.
23=Throttle sensor out of range or throttle set too high - TPS
86=A4LD 3/4 shift solenoid - Transmissions
89=A4LD - Converter Clutch Override solenoid - Transmissions
stalls probably from intermittent locked torque converter clutch
if it continues, look for failing TC lockup solenoid or damaged wiring...both TC lockup and 3>4 shift controlled by ECU thru wiring
Pablo,
i show 0.66v minimum tps signal and 4.66v max.
that's for a '96 4L EEC-V OBDII though
don't have info for your '89 OBDI system
could be intermittent dead aka open spot on TPS carbon resistor track
Thanks! I'll chek the signal.
The other quation. Is it possible to install cluster of Continental '89 in aero? Part N E90F 10849 AG. There is trip computer inside!
