Sponsored by: Real Truck
HEATED MIRRORS????
Old Nov 22, 2002 | 09:08 AM
  #31
pickupdan's Avatar
pickupdan
HEATED MIRRORS????
[updated:LAST EDITED ON 22-Nov-02 AT 10:14 AM (EST)]My 2003, F250 with the tow mirrors are heated.....
No switch, just allways on...
Dan Tucker
UPstate NY
Old Nov 22, 2002 | 11:50 AM
  #32
nafzimo's Avatar
nafzimo
HEATED MIRRORS????
>Dan Tucker
>UPstate NY
Always on? OR Always on when the truck is running? OR Always on when the truck is running AND the temp is cold?
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Nov 22, 2002 | 12:58 PM
  #33
pickupdan's Avatar
pickupdan
HEATED MIRRORS????
As per the onwer's guide....
Heated Mirrors...page 55
Both main mirrors are heated automatically to remove ice, mist and fog. The mirrors are automatically activated when the vehicle is started.
Note: The mirrors may be hot to the touch but will not burn. This is the normal condition.
The mirror heating elements are designed to operate regardless of the geographic location of the vehicle. There is no switch to turn on, or other operator involvement required other than to start the vehicle.
The spotter mirror, below the main mirror, in not heated...
We are getting snow tonight so we will see how the mirrors work....
Dan Tucker
UPstate NY
Old Nov 22, 2002 | 03:46 PM
  #34
Gwilkrrs's Avatar
Gwilkrrs
HEATED MIRRORS????
now that was an excellent answer. go right to the book.
now, can a 2002 with tt mirrors be turned to heat?
Old Nov 22, 2002 | 03:54 PM
  #35
Waxy's Avatar
Waxy
HEATED MIRRORS????
If I knew I'd tell ya.
The sure fire way to find out is to go and take one of your mirrors off and check it out.
Waxy
Old Nov 22, 2002 | 04:09 PM
  #36
FortyFords's Avatar
FortyFords
HEATED MIRRORS????
I'll say this.if you have a connector coming from your mirror with a dark green/violet and black(ground) wire in it, you have a mirror that already has a heating element in it.on that note you can do it ,if you get the correct parts! problably from and excursion.
Stated before !
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Nov 22, 2002 | 04:17 PM
  #37
Gwilkrrs's Avatar
Gwilkrrs
HEATED MIRRORS????
ok now how do you get the mirrors off?
Old Nov 22, 2002 | 04:24 PM
  #38
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
HEATED MIRRORS????
[updated:LAST EDITED ON 22-Nov-02 AT 05:32 PM (EST)]>ok now how do you get the mirrors off?
I pulled this from another thread -- credit where it's due, these are Yeti's instructions:
I can tell you how right now. Their are 4 nuts holding the mirror on.
First pull the black plastic cover on the inside of the door off, its where the top of the door and the window meet by the mirror.
Take the two larger rubber plugs out, now all 4 nuts should be visible.
If you have power mirrors, you will have to take the inner door panel off and peel back the sound barrier stuff and fish your hand in to unplug the mirror from the connecting plug. To take the panel off you have to pull your switches up from the panel, and remove the screw that holds the panel to the door, also remove the lower reflector and remove the screw , the panel will lift up , turn your switch panel to the side so it will slide through.
With the window down, so you can hold the mirror, remove the 4 nuts, carefull as so they dont fall into the door.
Put it all back together the way it came apart, should take you about 15 to 20 minutes per door.
Now a comment of my own -- if you're taking the door panels off, go ahead and put some Dynamat on. That stuff's not only great for performance sound systems, but it'll help anyone who wants to have a little less road noise in the cab. Start with the doors when you're doing your mirrors... and you'll find out that as soon as you've got some time you're doing the whole cab.
Also, TAKE LOTS OF PICTURES!!! I would really like to see the wiring harness and anything else you take apart in there. Maybe if someone does the heated mirrors mod, they might be willing to put together a parts list & instructions w/ pictures... sounds like article to publish on FTE... what does or Moderator think about that?
Old Nov 22, 2002 | 04:26 PM
  #39
Gwilkrrs's Avatar
Gwilkrrs
HEATED MIRRORS????
thanks!
Old Nov 22, 2002 | 04:54 PM
  #40
Monsta's Avatar
Monsta
Sit. Stay.
HEATED MIRRORS????
... what does our Moderator think about that?
I think it wil be an excellent addition to the currently in-the-works Super Duty FAQ page!
Old Nov 22, 2002 | 05:23 PM
  #41
haroutd's Avatar
haroutd
HEATED MIRRORS????
MMmmmmmm.... Super Duty FAQ Page.....
(said similar to how Homer Simpson says "MMmmmmmm.. Fudge...." -- and yes, I am drooling)
Old Nov 24, 2002 | 09:08 PM
  #42
MNCamper's Avatar
MNCamper
Post HEATED MIRRORS????
[updated:LAST EDITED ON 24-Nov-02 AT 10:20 PM (EST)]>there all ways on no switch ? must be controlled by gem
>module then!
>did you chk your owners manual?
>Thanks again
>Rich
The OM says, on p55; "Both main mirrors are heated automatically to remove ice, mist and fog. The mirrors are automatically activated when the vehicle is started. Note: The mirrors may be hot to the touch but will not burn. This is a normal condition. The mirror heating elements are designed to operate regardless of the geographic location of the vehicle. There is no switch to turn on, or other operator involvement required other than to start the vehicle. The spotter mirror, below the main mirror, is not heated and must be adjusted manually."
Edit: Oops! Sorry. Should have read through the rest of the thread before answering.
2003 F350 Regular Cab XLT 4WD V10 6-Spd 3.73LS - Ordered 06-Sep; Received 14-Nov
Old Nov 24, 2002 | 09:16 PM
  #43
MNCamper's Avatar
MNCamper
>MNCamper, How do you like your new truck? How many miles
>have you put on it so far?
About 150. I don't get out much.
I like everything about this truck. It is a ball to drive.
Shifting the transmission is like moving a stick in a bucket of molasses in January (in Minnesota) and I have trouble getting into the lower gears (R or L or 1) when stopped. I hope that this is just *newness* and that it will loosen up with use.
Old Nov 25, 2002 | 05:08 AM
  #44
BlueOvalBoy's Avatar
BlueOvalBoy
HEATED MIRRORS????
LittleRadio
Mar 5, 2011 04:48 PM
farm1966
Oct 14, 2010 12:15 PM
billygoat
Jan 17, 2007 08:10 AM
Superdutymac
Electrical Systems/Wiring
Dec 19, 2004 09:44 PM
VelocityDriver
Oct 23, 2004 08:12 AM
