Brake light switch issue
is there a way you can test the switch off the truck, compressed air maybe?
What are folks using for brake light switches? obviously this repro is faulty. Is there another choice?
As always, thx in advance for the help.
https://www.oreillyauto.com/detail/c...qXNDGuQiv9ymm_
ACDelco 12323538, U855
AMC 201466, A1271, J201466, J3145198, J4488306, JA001271
Advan-tech 3D5
Airtex 1S5366, 1S5367
BWD S194
Beck/Arnley 201-0304
CARQUEST Premium By WELLS 53-54491
Cartek 8676
Chrysler 1603328, 1622014, 201466, 3145198, 3191294, 4488306, A1271, J201466, J3145198, J4488306, JA001271
Duralast F4805
Ford 0A-13480, B8A-13480-A, B8E-13480-A, B9SF-13480-A, C1AF-13480-A, C1AZ-13480-A, D3KF-13480-AA, D3TB-13480-A1A, FFA-13480-A
General Motors 12323538, 1328118, 1972519, 1997725, 303056, 4766
Jeep 201466, A1271, J201466, J3145198, J4488306, JA001271
Kem EG1043
MasterPro 2-8676
Mighty Distributing System 3-850
Motorcraft SW24
NAPA Mileage Plus SL134SB
Renault 201466, A1271, J201466, J3145198, J4488306, JA001271
ROSTRA 62-0035
T Series SLS27T
WELLS 1S5367
I am of the opinion that many of the gripes of their reliability stem from improper installation where too much gorilla power was used along with an adjustable wrench (causing deformation of the unit) instead of a a more gentle consistent approach with a deep 6 point socket. There is no need to go all Hulk Hogan on it or anything. If you are afraid of it leaking, use some Gasoila soft set - but many units come with a sealant already on them. Or there is the "I put new brake fluid in it when I redid it not all that long ago.... 15 years ago..." - Of course the system fluid isn't going to be clean anymore! If your brake fluid is compromised preventing switch function, might as well get that taken care of instead of masking the issue by following the suggestions of the inevitable crowd of physical pedal switch advocates that will pile on. Why do it different when it can be done right?
Advan-tech 3D5
BWD S194
Cartek 8676
Duralast F4805
Kem EG1043
MasterPro 2-8676
Motorcraft SW24
ROSTRA 62-0035
T Series SLS27T
WELLS 1S5367
https://www.oreillyauto.com/detail/c/standard-ignition/standard-ignition-2-terminal-brake-light-switch/std0/sls40?srsltid=AfmBOooTySOzmGOdt68GjUdBby7C7O50kd7J xt0ff1qXNDGuQiv9ymm_
https://jniolon.classicpickup.com/wi...ightswitch.htm
Personally, I'd mount it with the wiring down to be a cleaner install and keep moisture and debris from sitting in the bowl, but that's just me.
Not do imply the jnolon switch install isn't a great solution, but I just mounted mine on the firewall under the brake pedal lever. It's a lot simpler. When I step on the brake the lever moves out and triggers the switch, brake pedal up it compresses the lever and lights off. It's a 3 screw installation. If you are worried about exposure to the elements put some dielectric grease on the terminals.
The other thread. Post #6 shows the firewall mounting set up albeit on a Chevy.
https://www.ford-trucks.com/forums/1...l#post21822122
