2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
auto start stop
Old Apr 14, 2026 | 09:30 AM
Mick83's Avatar
Mick83
auto start stop
I have a 2024 F-150 that came with automatic start stop.
I didn't like it and mostly turned it off.
A few months ago, President Trump signed something that eliminated the requirement for auto makers to have this feature on vehicles.
About the same time, my auto start stop went away. I no longer have to manually disable it and can't get it to come on (although I really don't want it on).
Has anybody else had this experience? Only thing I can figure is Ford sent out an update eliminating it.
Local Ford service department had no clue.
Thank you.
Old Apr 14, 2026 | 10:14 AM
vxed's Avatar
vxed
Maybe some wire somewhere came aloose. Or a fuse blew. Or it’s in your head. Rest assured Ford has not done an OTA update to remove this “feature”.
Besides, if they did that and the next administration signed something to reinstate the requirement (very likely), Ford would probably be in some trouble if they weren’t able to reimplement on every truck they disabled it on for whatever reason.
Now if they deleted it on brand new trucks is a different story, but they wouldn’t retroactively remove from trucks it came with.
Old Apr 14, 2026 | 11:17 AM
Beechkid's Avatar
Beechkid
agree with above.....something else is going on.............
Old Apr 14, 2026 | 11:39 AM
seventyseven250's Avatar
seventyseven250
your battery is weak.
Old Apr 14, 2026 | 01:54 PM
Mick83's Avatar
Mick83
Could be. Less than two years old and gets run pretty often.
But could be.
Old Apr 14, 2026 | 01:58 PM
85e150's Avatar
85e150
X2 on battery.
Old Apr 14, 2026 | 02:19 PM
Mick83's Avatar
Mick83
I'll get it checked.
But as long as it starts the truck, I am happy to have a slightly weak battery if I don't have to shut off the start stop. It was very cold here a while back and the truck started with no problem, so I don't think the battery is real bad.
Old Apr 14, 2026 | 02:41 PM
seventyseven250
Probably not "real bad". This is just a common early warning sign of a weak battery. They don't last as long as you'd think. If it was me I'd just plan to buy a new one before wintertime probably. By the time you notice "trouble starting" you are very close to "not starting".
Old Apr 14, 2026 | 03:44 PM
Mick83's Avatar
Mick83
Good advice.
How do you get all that stuff in your signature?
I have tried to add the 150 to mine a number of times and I am told that my signature is too long, can't be more than 6 lines (with the 150 added it's still only 3).
Old Apr 14, 2026 | 05:09 PM
seventyseven250
I haven't changed it in a long time, so I don't recall if I did anything special, but on my desktop computer with a big monitor, that's only two lines of text.
Old Apr 19, 2026 | 10:29 AM
Bumble2019's Avatar
Bumble2019
Veteran: Navy
I absolutely hate the start stop. I don't care what anyone says, can't be good for the starter and many other components.
Having said that, I put this on my truck the third day I owned it (Amazon prime took three days to get it to me).
Amazon Amazon
Works very well. Simply remembers where the switch was when the truck shuts off and puts it there after a start. So if you want auto start stop off, push the button, when the truck turns off it remembers that. When you restart the truck, it puts the button in that position, no need to push it. If you choose the turn it on, it remembers that as well.
The install for my F-150 was like 20 minutes. Connects in the wiring behind the glove box. Super easy. I put the same thing in my Caddie Escalade and that install was longer, basically because there was more trim to remove.
There are cheaper ways to do it, but, these are American made and I have put them on like 6 or 7 vehicles with no issues (first Ford, usually use Forscan). I wanted to rid myself of the PITA so installed that. I've had many doctor appointments since buying my truck, so haven't gotten around to updating my forscan license and getting it removed that way. This was just easier and quicker.
Should be noted I HAVE ZERO AFFILIATION WITH 4D TECH, I just loved the ease their products make getting rid of that nuisance.
Old Apr 20, 2026 | 08:53 PM
SMSTX's Avatar
SMSTX
Auto Stop Eliminator is another brand. They sell for almost all makes
Old May 30, 2026 | 10:06 AM
Bumble2019's Avatar
Bumble2019
Veteran: Navy
I know this is an older thread, but, had a thought. There is some connection to that system and the brake pedal sensor because if you just press the pedal enough to stop the truck but the stop/start thing will not kick in. Try really pressing down on the pedal and see if it kicks in.
Rmack941
2019 - 2023 Ranger
May 13, 2026 04:02 AM
Tncdrew
Jun 29, 2023 03:37 PM
Super Guest
2015 - 2020 F150
Sep 9, 2022 07:37 PM
renoduckman
2021+ F150
48
Dec 28, 2021 04:39 PM
JeffD11n
2015 - 2020 F150
65
Sep 21, 2021 07:34 PM
