Auto start stop technology
The auto start stop on the engine sounds really stupid to me. How does that actually work? I appreciate any input if the gang likes this or not.
Thanks Joe
As a matter of fact my Brother in law has ridden probably 200 miles with me and has yet to see the truck stop. I tried for two days stopping many many times to show him how it worked and the truck always found a reason not to.
It works by shutting down at the red-light or anywhere else you come to a stop. As soon as you lift off the brake it starts back up. Or if your cab gets too far from the set temp it will also go ahead and start.
When you lift your foot off the brake pedal, the engine will automatically start up again. It’s a very quick starting process so no worries about lag time .
If you don’t like this feature, there’s a button on the dash that can be pressed to disable this feature but you will have to hit it every time you actually turn the vehicle off.
Otherwise the button is over the infotainment screen.
It is far less intrusive than I had it imagined. Lol . With my dual exhaust it's more pronounced though.
Anyway,his results were such that he figured you had to be stopped at least 7 seconds to save enough fuel to make it worthwhile.
In my "testing", I have found that a 7 or 10 second stop is fairly rare in the driving I do, and that auto stop/start will drive you nuts in stop and go traffic with no benefit.
I do not think the system in my '17 is terribly aggressive, but I do shut it off and activate it only when I know I'm stuck a good long time.
I have ridden in a Range Rover Evoque and that system is much more aggressive than the Ford, and I couldn't see an easy way to disable it.
Mazda and Subaru also make it hard to disable.
This guy pronounces it "BS", asserting that it's value is only to the automaker for CAFE MPG purposes. That said, he only half condemns it from a reliability or engine wear standpoint. This is long and
LANGUAGE WARNING--LONG FORM "BS":
Been a member of the site for a long time on the 7.3 forum . Some looser totaled my truck so it’s a new F150
for me.
I own a shop and firmly believe that cylinder deactivation is highly over stated as an issue. Since 05 GM used it and very rarely had any issue. Called it DOD for a few years. Then afm. Especially inside of 150k miles. I can find a ton of them in Yukon envoy etc etc with 300k on the factory engine. Ford guys forget that around that time Ford v8 and v10 had been puking out spark plugs and ruining coils for several years. Not to mention the disaster that was the 5.4 triton. Where are all the 5.4 triton with 300k on the factory engine......
ID choose not to have the fuel management but it didn't scare me away .
Keep oil changed 99% of the issues go away. GM used a stupid screen design for a few years early on. But even then clean oil wouldn't clog it. Ill use mobil 1. 3k miles per oil change . I use it at 5k intervals in my mach 1. And 10k intervals in the Toyota. 180k miles with no issues but I believe different engines have different needs.
It seems like the main concern people have is the increased wear on the starter. But it's important to remember that the starters and flywheels used for engines with this feature are specifically designed to handle the increased load. They've been used for 6 years now in the F150, and I've not heard of one failing. I'm sure it's happened, but it's far from a common problem. I think this is like worrying about wearing out your transmission because it shifts, or your pistons wearing out because they're moving up and down so fast. They're designed for the task, so it's not worth worrying about.
All my vehicles are old, never driven anything that does that. My thought was it doesn’t seem necessary for the engine to shut off when I’m at a stop sign for 2 seconds.
