cat removal
Old Dec 10, 2003 | 12:50 PM
remmers's Avatar
remmers
cat removal
if i take off the pre-cat and cat on my 91 f-250 351 and put a straight pipe on it will this cause my truck to run bad (back pressure) or is it ok to remove this
Old Dec 10, 2003 | 04:34 PM
modru2004's Avatar
modru2004
this belongs in the exhaust forum. your not hurting anything by taking of your cat or pre cat other than the enviroment. when you say straight pipe do you mean dual exhaust with the pipes coming straight out of your manifolds? or did you mean to put a y pipe on and run single?
Old Dec 12, 2003 | 07:37 PM
swampo's Avatar
swampo
It shouldnt cause you to burn up your rings or anything like that as long as you dont use big pipe when I do this I always put in an x pipe just to be cirtian but you should get by and its gonna sound great
Old Dec 14, 2003 | 11:19 PM
yellowjeep76's Avatar
yellowjeep76
the pre cat is in place to reduce NOx (oxides of nitrogen) and the second cat reduces HC (hydorcarbons) and CO (carbon monoxide) you don't get a performance increase from removing it unless it is already plugged.
Old Dec 14, 2003 | 11:58 PM
87joe302racetruck's Avatar
87joe302racetruck
cat removal
ive heard that when taking the cat off you need to put the oxygen sensor in the new pipe or it will not run right that is if you have an efi. not to sure if its true thats just what anexperienced mechanic told me
Old Dec 15, 2003 | 02:49 AM
oxford01gt's Avatar
oxford01gt
It won't be a problem. You will need some type of MIL (multi-function indicator light) eliminator to keep the rear O2 sensors from triggering the MIL indicator (check engine light). Dallas Mustangs has them for the Mustangs...might have one that would work for a 351 equip truck. I'd say a good amount of the V-8 Mustangs (in areas without emissions inspections) have a "off road" midpipe. As far as not seeing any performance gains, I beg to differ. On a 99+ 4.6 Mustang an off road X or H pipe is one if the biggest bang for the buck modification you can make. Gains of 20+ rwhp have been dyno proven. When I add the Thorley headers to my truck I plan on having a catless mid pipe constructed.
Old Dec 15, 2003 | 05:19 AM
christop43's Avatar
christop43
hee haw... just gow ana remove thmn cats.... themn scientists aint know what they ar takin about anyway....
Don't ruin it for the rest of us...
Old Dec 15, 2003 | 07:11 AM
EPNCSU2006's Avatar
EPNCSU2006
You'll only need an MIL eliminator if the truck is OBD-II. Otherwise, leave the O2 sensor as it sits, it should still work.
Old Dec 15, 2003 | 01:19 PM
rebel_ford4x4's Avatar
rebel_ford4x4
how do i know if my 92 f150 is OBD-II? and where do you get mil eliminators?
Old Dec 15, 2003 | 01:27 PM
MustangGT221's Avatar
MustangGT221
Only 96 models are OBD-II...also I believe some 95's are. The OBD-II system has more than 1 oxy sensor, one before and after the cat. That would require a change, but your truck only has 1 sensor infront of the cat, so it doesn't matter what's behind it.
Old Dec 15, 2003 | 01:40 PM
rebel_ford4x4
would i need a mil eliminator then if i "lost" my catalytic converter?
Old Dec 15, 2003 | 02:09 PM
MustangGT221
no you wouldnt need anything because as i said the sensor is before the cat...so it doesn't matter what you do after the sensor.
Old Dec 15, 2003 | 03:10 PM
rebel_ford4x4
ok thanks
Old Dec 16, 2003 | 12:21 AM
alabamabuddog's Avatar
alabamabuddog
all you have to do is remove the cats! It wont hurt any thing. Mine is gone and been gone and I had 200,000 miles on this motor.
Old Dec 21, 2003 | 12:31 PM
vortechf150's Avatar
vortechf150
a company called bassani makes an offroad y-pipe to replace the pipe you are taking off, new pipe, and great quality, and you will notice a power difference. believe it costs around $250, but all done, and bolts up to you manifolds, easy to do yourself. and you do not have to worry about your oxygen sensor, it just reads the gas before the cats.
dmncoon
Nov 11, 2008 09:24 PM
tmbante
Modular V10 (6.8l)
Jul 10, 2007 07:15 PM
kgglass
Mar 8, 2005 06:10 AM
ehuhn
Exhaust Systems
Jan 11, 2003 02:03 PM
cubster
Exhaust Systems
Dec 19, 2001 10:28 PM
