Modular V10 (6.8l)
Removing the Cat
Old Jul 9, 2007 | 10:17 PM
tmbante's Avatar
tmbante
Removing the Cat
I have the V10 in my RV. In TN I dont have to have it pass emissions. Would it be worth it performance wise to remove the cat?
Old Jul 10, 2007 | 01:18 AM
Monsta's Avatar
Monsta
Sit. Stay.
Not really. Guys that have have reported no real gain and a much louder exhaust note.
Cats are a FEDERAL mandate. Removing it violates Federal emission laws.
Old Jul 10, 2007 | 05:48 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
only if you freed up the flow in the rest of the exhaust system
Old Jul 10, 2007 | 07:07 AM
jonrjen's Avatar
jonrjen
Before you think too deep about removing the Cat, check your state laws a little more in detail. Some vehicle don't have to pass an emissions test due to the GVW and or the year of the chassis. Texas will allow an emissions by-pass on a vehicle over a GVW of 9,900 pounds. This is in large because of the limited inspection stations that can access the size of a RV or big delivery box truck in an inspection bay due to physical size of the vehcile and the limited door heigth or bay size.
However Federal law still requires the cat be installed. The fines for an emission violation are pretty stiff.
Old Jul 10, 2007 | 10:14 AM
Bear River's Avatar
Bear River
Former ******
The cat is not the major restriction in the exhaust system. Look elsewhere to improve things. You might gain some power by using dual large body converters in parallel (they still need to be rated to the weight), but I'm not sure the gains would be significant. I would look at a freer flowing muffler instead.
Old Jul 10, 2007 | 10:17 AM
Big Orn's Avatar
Big Orn
There is no need to remove the cat. It makes no difference whatsoever. If you go with other mods that will not perform with your cat, then get a cat that is compatible. JMHO on that.
If you don't believe me (us) then be sure to keep it whatever you do. You will re-install it some time soon.
Old Jul 10, 2007 | 05:46 PM
KubotaOrange76
put headers on it
Old Jul 10, 2007 | 07:15 PM
captchas's Avatar
captchas
Guest
put on a banks kit and leave the cat right where it is.
i pulled mine and found myself $1285.00 dollars in the hole for new ones. the v10 most have some back pressure to run correctly
tattooed_yoshi
May 20, 2013 03:37 PM
Shwan_89HD
Dec 5, 2012 01:38 PM
Ravenwood Ranch
General Diesel Discussion
Aug 11, 2009 06:33 PM
PigFarmer
Exhaust Systems
Mar 22, 2002 03:45 AM
cubster
Exhaust Systems
Dec 19, 2001 10:28 PM
