Let’s go! E4od removal!
Old Mar 14, 2026 | 06:13 PM
  #31
jktrevecca's Avatar
jktrevecca
I'm about to just buy this and dive in. Is this kit okay if I also install the trans-go shift kit? What else should I proactively purchase? Thanks
Amazon Amazon
Here is the classroom video series I've been watching and that I will follow as I'm rebuilding. Have you heard of it?
Old Mar 14, 2026 | 06:41 PM
  #32
FORDF250HDXLT's Avatar
FORDF250HDXLT
Yeah and if you want to really dive in, I posted that here along with the update info and other stuff you'll find handy if you want to dig in and reman it to '95+ (or even beyond, but with the power of the IDI engine, there's no need at all to go beyond '95 spec, that is you're N/A or just basic turbo kit power level).
How To Reman The E4OD/4R100 - Complete Video Walkthrough
I've got my old original trans from the F450 in the garage. I really need to do this myself. I was going to this winter but I ran into some health issues (battling the big C but I'll kick it's ***). Go for it man! It should be a fun project! I'm gunna tear into mine at some point. Just go through those pdf files and do a bit of research first. You may want to at least upgrade the center support and whatever supporting parts go with that.
I'm going to warn you though, you reman the trans with the tugger kit and that triple disc converter, you're never going to want to sell the truck after.
Old Mar 15, 2026 | 11:36 AM
  #33
jktrevecca's Avatar
jktrevecca
Screw the big C. I’m sorry you’re in the ring with that punk. Cheering for a knock-out for ya 😎
Old Mar 16, 2026 | 09:13 AM
  #34
jktrevecca's Avatar
jktrevecca
@FORDF250HDXLT where are you located? I’d like to give you dinner and drinks either in person or via gift card for all of your help.
here are videos of the beginning or my tear down. The pump is sketchy. The friction plates I’ve seen so far don’t look bad at all. Thoughts?
Old Mar 16, 2026 | 11:07 AM
  #35
FORDF250HDXLT
Yeah, the pump is shot, but you're right, your discs do look good. At least the ones you pulled from the OD pack. It looked like you just wanted to keep going haha. Go much more and you might as well put it back together with new parts. Someone with experience inside will have to help more than I can, but I don't see anything obvious. Though I've only rebuilt one trans, a C6 back when I was a teenager and I don't recall much about it anymore. You're making me wish I felt good enough to tear into my burned out E4OD now, too.
Post your videos here if you want to see about more opinions on what you showed:
https://www.ford-trucks.com/forums/forum69/
See if someone thinks you should keep going or just toss a pump in it and run it.
I mean obviously, it would be cool to see the condition of some more clutch packs, but how deep to you want to go to inspect, right? How many miles are on the truck? When I put a pump and converter in, to nurse my old one along, it had nearly 200k and then it just slipped and lost it's gears the next season or two. I bet your trans is in better shape than mine was.
firstrider
Apr 19, 2025 03:46 PM
run6.0run
Sep 29, 2017 05:48 PM
Backwoods351
Offroad & 4x4
May 6, 2015 05:34 AM
bpounds
S. California Chapter
Apr 4, 2014 08:30 AM
run6.0run
May 5, 2013 07:45 PM
