2026 F250 trailer brake controller programming
Old Mar 7, 2026 | 08:52 AM
Squints88's Avatar
Squints88
3rd Gear
Hi there I’m seeking some advice with using FORScan to program a factory trailer brake controller to my 2026 250 STX. Has anyone trikes this yet?
This is my first time using forscan, I changed the 3 settings in ipc first to no avail. I found settings for the trailer brake controller in abs and pcm as well and switched them on with no success. I have since reverted all settings to factory. Am I missing something or is it possible that I am not able to program this myself on a 2026?
Old Mar 8, 2026 | 08:02 AM
techrep's Avatar
techrep
have you checked fuses ? fuse #54 needs to be installed and good.
Old Mar 8, 2026 | 08:26 AM
Squints88's Avatar
Squints88
3rd Gear
Yes I have as well as #27 I believe under the dash
Old Mar 25, 2026 | 07:50 AM
ford_wise_guy's Avatar
ford_wise_guy
2nd Gear
Did you ever get this resolved? I'm trying to do the same install on my 2026 F250 XL.
Old Mar 25, 2026 | 08:33 AM
Shadowrider123's Avatar
Shadowrider123
Need to do the same on my 25 STX.
Old Mar 25, 2026 | 08:57 AM
ford_wise_guy
2nd Gear
Its crazy for a 3/4 ton truck not to include it. I didn't even think it was a question I had to ask
Old Mar 25, 2026 | 10:06 AM
Squints88's Avatar
Squints88
3rd Gear
It is crazy isn’t it. I missed the fact that it wasn’t in there on my test drive.
I was not able to get it to work with FORScan, I ended up dropping it off at the dealer and having them program it, $50.
Old Mar 25, 2026 | 10:13 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Bean counters gonna count beans. Cuts everywhere on what should be standard.
thelongbus
Dec 1, 2025 11:37 AM
CollinPirner
Jul 9, 2025 09:19 AM
77bluetruck
Feb 15, 2024 01:19 PM
Don Ridley
2021+ F150
Jun 5, 2023 05:18 PM
Spoojr
2015 - 2020 F150
Dec 2, 2021 10:30 AM
