Trailer Brake Controller Issue
Old Jan 14, 2026 | 10:52 AM
Rustyturn's Avatar
Rustyturn
6th Gear
I have a 2024 F-350 and cannot set the trailer brake controller high enough to make the wheels lock up. I have the Trailer Brake Effort set to high and the Trailer Brake Gain set to 10. When I slide the controller to activate the trailer brakes the trailer wheels do not lock up. The trailer is a 28 foot Bigfoot travel trailer with dual axles, electric brakes, and 7610 maximum weight. Has any one else had this issue? What am I missing? Pretty sure that to adjust the braking at 20 to 25 mph you turn everything up until the wheels lock up and then back it down until they turn when brakes controller applies brakes to trailer only.
Old Jan 14, 2026 | 11:03 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Because of how the ITBC works, I don't think you will be able to truly get the brakes to lock up. It works with the ABS system in the truck, which is intended to NOT let the wheels lock up.
In emergency situations, you don't want the tires on the trailer to lock up anyway, as this can lead to loss of trailer control.
I set my electric brakes by finding an empty road, getting to about 35 mph, and trying to stop quickly. If it feels like the truck is getting 'pushed,' the gain is too low and I turn it up. If it feels like the truck is getting 'pulled,' the gain is too high and I turn it down. Ideally the truck and trailer should be stopping evenly, but I would prefer a slight pull over any push at all.
Old Jan 14, 2026 | 11:59 AM
shawnee1's Avatar
shawnee1
It should be possible to lock up the trailer brakes using the manual slide on the controller to activate the trailer brakes while not applying the truck's brake pedal. This is what the OP is trying to do and is the proper way to set the controller gain.
To the OP, have you had the brakes checked on the trailer? Were you able to lock up the trailer brakes using a different tow vehicle?
I need to reset the gain frequently for my dump trailer as the load is never the same. Always able to lock up the wheels until I had the brake shoes replaced. It took a while for the shoes to bed in such that the wheels would lock up as they once did.
Old Jan 15, 2026 | 09:31 AM
Thealien's Avatar
Thealien
my 2023 F250 is the same way. I’ve had it. I have taken it toa couple of different dealerships and they all say test out just fine. I checked all the brakes on my trailer even used it on a different vehicle and that vehicle could lock them up. I’m not totally thrilled with my factory brake controller
Old Jan 15, 2026 | 09:42 AM
powerboatr's Avatar
powerboatr
iirc
You should feel trailer slightly pull back on truck
When you brake normally
Panic braking it should come very close to lock up
The system is designed to try to prevent lock up, via modulation of amps to the brakes, based on the info the abs is sensing...its not abs for the trailer
but it is real close
so your trailer does not loose grip on road and slide out of control or cause truck to suddenly gain momentum from sliding trailer
if you squeeze the tbc to full at 3 to 5 mph and if it locks the wheels. Its working.
if it does not...inspect the trailer brakes
also..do you have any dash lights of trailer disconnected etc.
If you have to set gain at real high levels as in max.
to get the slight pull back at normal braking effort
​​then the brakes need to be inspected at all wheels.
are they disc or shoe style
Shoe style have to be adjusted evenly across all wheels and have just a touch of drag..
Trailer brakes are notorious for not being adjusted
Old Jan 15, 2026 | 10:38 AM
99powerstrokedF250
Originally Posted by powerboatr
iirc
This is pretty close to what I have always been taught - if the controller is working properly, there are very few instances where the brakes should lock up. If it won't in those few instances, then the trailer brakes are most likely the culprit. I would inspect those first.
Something most people don't realize is that the ITBC is NOT like the old pendulum style, or even the Prodigy-style that 'simulate' what the ITBC does. It actually works with the truck brakes, modulating applied voltage based on the brake pedal input to act as ABS for the trailer. And it doesn't WANT to let the tires lock up if the truck is moving, because it means a loss of control.
Old Jan 15, 2026 | 10:54 AM
Rustyturn's Avatar
Rustyturn
6th Gear
shawnee1, Yes, this is what I am trying to do. If I don't get any better choices then I will have the trailer brakes checked. Thanks
Old Jan 15, 2026 | 10:55 AM
Rustyturn's Avatar
Rustyturn
6th Gear
Thealien, I am disappointed to hear this, but not surprised. I hope I can get different results from you but I am not counting on it.
Old Jan 15, 2026 | 10:58 AM
Rustyturn's Avatar
Rustyturn
6th Gear
powerboatr, Everything is connected. They are shoe style brakes. Doesn't lock at 3 to 5 mph. I guess brake inspection is next.
Old Jan 15, 2026 | 11:01 AM
Rustyturn's Avatar
Rustyturn
6th Gear
99powerstrokedf250, Yes, must be the trailer brakes. I will post what we find.
Old Jan 15, 2026 | 01:23 PM
kbass24emtp's Avatar
kbass24emtp
I can only get my trailer brakes to lock up using the manual lever.
Old Jan 15, 2026 | 02:34 PM
shawnee1's Avatar
shawnee1
I've had the empty dump trailer brakes lock up when braking using the brake pedal. This happened when I forgot to lower the gain after unloading.
Old Jan 15, 2026 | 03:21 PM
BowtieConvert's Avatar
BowtieConvert
Are they electric drum brakes or EOH discs? I have a 30' Diamond C gooseneck w/ EOH discs and I was having issues like you described. The dealer ended up having to install on of these in order for it to work correctly.
https://hydraprousa.com/products/ele...ility-adapter/
For the record, the trailer is equipped with the Deutsche Hydrapro EOH brake actuator.
Old Jan 19, 2026 | 06:10 PM
Rustyturn's Avatar
Rustyturn
6th Gear
I wanted to see the adapter your dealer used but the link is not working.
Old Jan 19, 2026 | 08:00 PM
BowtieConvert
Google hydraprousa.com
I also have an ATC enclosed trailer with EOH discs but with a different controller. It’s always worked fine. The Diamond C has the controller that’s linked.
jimmystoys
All Things Towing
Jul 31, 2023 02:20 PM
tony montana 42
All Things Towing
Sep 13, 2017 10:11 AM
Burdpete
Apr 10, 2016 03:24 PM
Great Danes
6.7L Power Stroke Diesel
78
Nov 14, 2013 09:25 PM
Bronsonh
Apr 27, 2009 10:55 PM
