Sponsored by: Real Truck
mystery warning chime
Old Dec 8, 2025 | 07:35 AM
offshore's Avatar
offshore
Trailering
My new to me 2001 F350 has a persistent warning chime i cant seem to locate the source of. Key out engine off when door is open it just keeps ringing, sometimes it doesn't do it but most times does. All interior lights and headlights are off and bell does stop once doors shut. What other circuits (with key out) does the warning indicate other then lights left on? Also would a scan be able to indicate anything? Was actually thinking bad headlight switch but dont want to just throw parts at it if there things i can look at.
Old Dec 8, 2025 | 07:41 AM
projectSHO89's Avatar
projectSHO89
Probably the key-in-ignition switch attached to the ignition lock cylinder.
I usually just permanently disable mine anyway by clipping the black-purple wire.
Old Dec 8, 2025 | 08:13 AM
offshore's Avatar
offshore
Trailering
thanks i wondered if there was a way to just disable it. I know there really isnt a chime speaker to just clip. Where is the blk/prpl wire located, in the column? Going to try and correct it if i can but im not apposed to eliminating it.
Old Dec 8, 2025 | 10:32 AM
projectSHO89
I removed the lower column shroud to get to that wire.
Old Dec 8, 2025 | 11:53 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
One day I may fix that exact issue on mine, but after 3 years it is still on the bottom of the list of stuff.
Old Dec 8, 2025 | 02:21 PM
victorcharlie's Avatar
victorcharlie
Try adjusting the dash light dimmer switch.
Old Dec 8, 2025 | 04:06 PM
projectSHO89
There is no alarm/chime associated with the "dash light dimmer switch".
Old Dec 8, 2025 | 05:43 PM
offshore's Avatar
offshore
Trailering
with the dimmer switch rotated all the way up the dome light and i believe the bed lights are held on. This would trigger chime to stay on (not the cause in my case)
Old Dec 8, 2025 | 08:24 PM
projectSHO89
No, it won't. There is no input to the warning chime circuit (in the GEM) related to the courtesy light circuit. The only inputs are the key-in-ignition switch, park/headlights, and the door switches.
Old Dec 8, 2025 | 10:05 PM
ashleyroachclip's Avatar
ashleyroachclip
You can unplug the key in ignition chime , under the shroud on the column. No need to cut wires .
it is a single wire ,leading up to the tumbler .
Old Dec 9, 2025 | 12:22 PM
offshore's Avatar
offshore
Trailering
my bad heck i thought they all did that. Im coming out of a 2500 Ram as my daily and happily back in an F series
mtford
16
Nov 14, 2023 08:31 PM
tomfordgt
May 13, 2017 05:59 PM
Robert Urbahns
2004 - 2008 F150
Dec 24, 2016 01:27 AM
sctrailrider
Aerostar
Aug 6, 2009 02:09 AM
93nighthawk
Aerostar
Jun 19, 2009 03:10 PM
