Aerostar Ford Aerostar
Please "chime" in
Old Aug 2, 2009 | 08:58 PM
sctrailrider's Avatar
sctrailrider
Please "chime" in
You know the chime that sounds when you go to leave the van and you've left your lights on? Well mine is working just the opposite. Ride down the road, turn on the lights and the chime comes on. Open the door and the chime stops. It sounds off whenever the lights are on. Anyone have an idea what's gone wrong?
Thanks
Old Aug 3, 2009 | 09:14 AM
Bear River's Avatar
Bear River
Former ******
Could be a problem in the ignition switch. The engine might be on, but parts of the switch might think that your key is not in. It is the key removal that triggers the chime.
Old Aug 3, 2009 | 02:33 PM
xlt4wd90's Avatar
xlt4wd90
On my cars (87 Mustang and 90 Aerostar), I do not believe the key is involved in the alarm triggered by the exterior lights. I think it's just when you open the driver's door with the exterior lights on. I don't know if it's just sensing the lights being on, or the light switch being on. I would check the headlight switch. Maybe the later models got more intelligent so that they do not chime in these conditions when the key is also on.
The key-activated alarm comes on when there is a key in the switch and the door is opened, to warn you about leaving your key in the switch. Again, maybe the later models will not do this if the key switch is on.
Old Aug 3, 2009 | 11:07 PM
sctrailrider
Headlight switch was replaced in January. This problem just recently came up. Running or not, if the headlights are turned on with the driver's door shut, the chime comes on. Open the door, chime goes off.
Old Aug 6, 2009 | 02:09 AM
Bugzuki's Avatar
Bugzuki
Try spraying some WD40 on the Driver's Door latch mechanism. I have seen that correct several different door alert issues on several different types of Ford vehicles. Worth a try.
SRT
2004 - 2008 F150
Jun 5, 2016 10:13 PM
Mikey_23_ny1
Electrical Systems/Wiring
Oct 28, 2015 01:11 PM
Douglas Highlander
13
Jul 27, 2015 08:30 PM
moymurfs
Apr 28, 2015 07:22 PM
Poncho450
Apr 24, 2015 08:16 PM
