1952 Dual Trumpet Horns
Old Nov 18, 2025 | 09:51 AM
Ford52F2's Avatar
Ford52F2
Well I keep adding projects one after another. I have a tub of Trumpet Horns that I am going to use for my 52.
There is seven Horns with two sets of matching Dual Hi-Lo Trumpets. These Trumpets may have went to trucks or cars.
Wondering is the Hi - Lo tone range is how the armature is set or about the length of the trumpet?
I kind of disassembled most of the trumpets without thinking about the Hi - Lo tone.
Now I have an assortment of Armatures to choose from, and I need to know how to select them for Hi - Lo tone. Will have to verify if the Armature even works. My 52 went through a flood (March 1997) and I started to work on the Horn about five years later. The inside still had wet mud that I poured out then cleaned it up. It still sounded out when I put it back together. Built Ford Tough.
I'm planning on doing a Five Star Deluxe I have nearly all Five Star items except for hood trim. Planning on ghosting it on the hood. Now just need to pick the Horn Trumpets to use. Have only mounting Bracket for passenger side. Will need to create the one for the driver's side.
Have started to gather the truck parts that I am not using for sale or give away later.
Ford52F2
Old Nov 18, 2025 | 11:27 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
For 51/52, this is what I have going by the book for horn information:
Hi-Tone (Rightmost):
There were three options ~16 to 17" long.
1C-13832-A 16 7/8" long, acorn shaped base
1C-13832-B 16 1/2" long, rounded shaped base
1C-13832-C 16" long
Lo-Tone (Leftmost):
Again, three options, ~18-22" long.
1C-13833-A 21 1/4" long, acorn shaped cover
1C-13833-B 21" long, rounded cover
1C-13833-C 18.63" long
Old Nov 19, 2025 | 07:38 AM
Ford52F2's Avatar
Ford52F2
Then by what you sent the 13833-C should only be 18.63". But the long horn that was on my truck is nearly 20" long though. Will go through the other horns and check.
Found a matching shorter horn. As you can see, I'm missing the other mounting brackets. Will have to Fab one up.
Looked on the FORD TRUCK PARTS Illustration pg. 339 Section 145, it shows the forward bracket as p/n13820. Doesn't show any other horn brackets. It may be the complete assembly number for all the brackets. Doesn't list any screws on that list. But if you go to the FORD TRUCK PARTS Text pg. 716 Section 134, it lists a Universal Type bracket B9A-13830-A. The 13820 brackets can be universal, but the L-shape bracket will need to be mirrored. Can't be Universal because it needs a mirrored bracket. It also list the screws needed. These are two carriage bolts but need another carriage and slotted bolt for 13820.
Ford52F2
Old Nov 19, 2025 | 08:32 AM
bmoran4's Avatar
bmoran4
You at referring to the 1964 printing of the catalog which is over a decade away from production and relied on the (then) current inventory practices. It is not very helpful in cases like this.
I think this is what you are after:
Projector support:
1C-13820 for use with any of the 6 horn options.
Hardware:
23356-S7 1/4"-20 x 9/16" bolt
33795-S7 1/4"-20 nut
34940-S2 1/4" lock washer
44815-S .26" ID x .50" OD washer
RH with spacers: 1C-13830-A (for 1C-13833-A, 1C-13833-C)
RH without spacers: 1C-13830-B (for 1C-13833-B)
LH with spacers: 1C-13831-A (for 1C-13832-A, 1C-13833-C
LH without spacers: 1C-13831-B (for 1C-13832-B)
Augmented Spacers for 1C-13830-B and 1C-13831-B without spacers:
51A-13827-B .16" thick (for 1C-13832-B and 1C-13833-B)
1C-13827-B .28" thick (for 1C-13832-B and 1C13833-B)
Mounting Hardware, upper hole:
23376-S 1/4"-20 x 3/4 bolt
44720-S8 1/4" washer
Lower hole:
39050-S8 1/4"-20 x 1/2" bolt
Old Nov 25, 2025 | 09:39 PM
Ford52F2's Avatar
Ford52F2
Still working at it.
got my two painted, now to check the armatures. My long black horn now measure correctly for my year, but the shorter one is 16.5 inches.
Ford52F2
Old Nov 28, 2025 | 05:01 PM
Ford52F2's Avatar
Ford52F2
Did a few things today. Assembled horns
haven't tested them yet. Also cut out mounting pieces for driver side.
Still need to finish them.
Ford52F2
Old Dec 4, 2025 | 07:58 AM
Ford52F2's Avatar
Ford52F2
Horn Spacers, Does anyone have a good photo of one?
from bmoran4
Is it a square piece of metal or a piece bent to fill the space?
Ford52F2
Old Dec 4, 2025 | 08:24 AM
bmoran4's Avatar
bmoran4
These are not pictured on any truck parts catalog that I can find, but I was able to find them in another application (ignore everything else as they are different):
Old Dec 6, 2025 | 10:46 AM
Ford52F2's Avatar
Ford52F2
Thanks for the info.
I think these are the 13827 spacers
Hunting for photo of the spacer that goes between bracket and hood side which it probably a square type maybe round.
Ford52F2
Old Dec 6, 2025 | 11:02 AM
bmoran4's Avatar
bmoran4
13827 is a group number denotes a spacer, but not a specific spacer. You need the full part number to get the specifics. Same goes for what I think you meant to be 13830, which is NOT a spacer, but a projector bracket. I've shared a whole outline above: https://www.ford-trucks.com/forums/1...l#post21703082
Here are some pictures from my RH (Passenger side) horn installation:
Old Yesterday | 09:53 PM
Ford52F2's Avatar
Ford52F2
Passenger Side
Driver's Side
Now on to the next project.
Also when I went to the KY Auto Swap meet last week, I found both dual Horns for $20 bucks. Now I have an extra set.
Ford52F2
Louisville KY
bario andretti
May 18, 2025 07:22 PM
3twinridges
16
May 9, 2017 02:27 PM
aaronbauer
Jul 16, 2015 08:31 PM
Fyrhosr
Jan 22, 2015 07:20 AM
51PanelMan
15
Aug 23, 2006 05:14 PM
