horn install
Old Jul 8, 2015 | 05:53 PM
aaronbauer's Avatar
aaronbauer
horn install
Would someone mind posting a few picture of how the horns are mounted under the hood? I have had mine off so long, I forget how they are mounted...I should have taken more pictures...
Old Jul 8, 2015 | 06:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What year and model is your truck? You can add that info to your Signature so we never have to ask and you don't have to type it a million times. Go to UserCP and Edit your Details.
Old Jul 8, 2015 | 06:34 PM
aaronbauer's Avatar
aaronbauer
Sorry guys...
I have a 1951 Mercury M1 (same as Ford F1)
Signature has been edited.
Old Jul 8, 2015 | 06:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I have only a single horn
Old Jul 8, 2015 | 09:23 PM
aaronbauer's Avatar
aaronbauer
Thank you very much...
My truck has a low and high pitch horn. One goes on each side of the hood.
Here's the link to my build
https://www.ford-trucks.com/forums/1...-restomod.html
Old Jul 9, 2015 | 10:43 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Here's my 2 cents.
I mounted these horns under the hood of my '51 and it affected the hood springs in a bad way.
Before the horns were installed I purchased two new Reproduction springs and put them in. The hood would open and stay fully up. I was quite happy with the difference the new springs made.
Then a few weeks later I put in the two horns, mounted exactly like the picture above. The hood would barely stay open, as if the horns were too heavy. On warm days the hood won't stay up at all and I now have to use a home-made prop rod each time I open the hood. I keep the rod in the bed. It's very discouraging because the new springs worked great and if I bought another set I probably won't have any difference with the horns there.
It's something I deal with but wanted to share that and see if anyone else here has any similar experience with this situation.
Tom
Old Jul 9, 2015 | 10:56 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Hard to believe the horns would make such a difference. The heavy part is right over the pivots.
Old Jul 16, 2015 | 08:31 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I have the twin horns, but I think Ross' pic shows the mount better.
Just make sure the mount brackets make good contact with the hood for the ground, or the horns(s) won't work.
Oh, and the wingnuts were just on there for a temporary mount.
3twinridges
16
May 9, 2017 02:27 PM
timm1564
1947 and Older Ford Trucks
Dec 21, 2014 01:22 PM
aussiecowboy
Apr 30, 2013 09:01 PM
51PanelMan
15
Aug 23, 2006 05:14 PM
51PanelMan
Apr 3, 2005 03:43 PM
