Should be the same as my 51. They are mounted on the side of the hood. Here is a picture I found on line. Most just had one on the PS. 5 Star Deluxe had both.
I am am going to need 8 clips, part 356687-s for the horn connecting wire and the headlamp crossover wire. Does anyone have a picture of one so that I know what I am looking for?
I'm fairly certain the '51 & '52 HL Crossover are the same part #. I just completed replacing the original. It's ~$19 through earlyford.com. The part # to the horn from the horn relay is shown in one of the pictures below. Here are pictures:
I have one trumpet horn, but it's not installed yet. Will push a photo over once it is done.
Henry, you remember Henry. The truck that I took to my buddy back in October to have the front end done. Well, he has a single horn on the passenger side. It is now 12 volt and I cannot wait to get him back and pull up behind some ********* that is texting. I hit the horn and if I am lucky, the dumb ******* will have a coronary! In case you haven't heard what a 6 volt horn sounds like when hooked to 12 volt, you are missing something.
After a bit of introspection I surmise my reading for comprehension skills are in need of refinement. The question was about the clips, and not the wire set up.
Thanks for this post! I now know what the horns look like that I am missing-my trucked shipped to me after the po stripped a bunch off of it... If you all find another set of horns-let me know.
