I just bought a 1993 F250 with the 460, and within 40 miles the transmission blew up.
I'm going to buy a used transmission for the time being until I can afford a reman, my budget is pretty strict as I'm still in school. When buying a used tranny, what procedure should I take before installing it?
I'm for sure flushing the cooler lines, but would like to know whether or not I should also flush the transmission itself, as I'm assuming its been sitting around for some time.
I'm open to any and all tips, this transmission is gonna have to last me a while, and I would like to do everything I can now to extend its life.
I wouldn't flush it. Unless it's been open to the weather, the fluid is probably fine. But, what you want to see is a clean red color and no burned smell. You may need to top it off.
Replace the front seal, the rear seal, and the filter. Check the magnet when you have the pan off.
Ensure the electrical connections are clean and that they fully engage when you connect them.
Meant "Blew Up" in a figurative manner, I see how it was unclear though.
Last person who rebuilt the trans messed up the torque converter, which caused it to overheat was reaching almost 400 degrees. I'm assuming the clutch packs are fried, all the seals are ruined. Partially my fault for driving on a transmission that was slipping as bad as it was, but I was tired and wanted to go home so I took my chances. I had just bought the truck, so I'm not certain what went wrong during the rebuilding process, but something very bad clearly.
Yup, ok, blew up fits the bill.
More than likely torque converter not seated all the way in, bolted trans to engine which in turn breaks the front pump. Front pump not working, the trans is cooked.
You will never know if a second hand trans is also cooked, unless you see it drive and/or really trust someone.
The next trans you buy second hand could easily have been another one where someone messed up installing the torque converter.
It is a risk we all take buy used old parts.
I've bought a few old trans, but specifically for the internal parts, not for a swap.
Whenever I swap in a used trans it gets new fluid and filter, and front and rear seals. If it doesn't have a rubber re-usable pan gasket already, it gets one. A shift kit or valve body from the old trans already with one installed, always goes in too.
Since it's an E4OD, I would flush the solenoid pack connector out and apply a light coating of dialectic grease on the pins too, same with the truck side connector.
