First time Ford owner
Old Jan 25, 2017 | 09:58 PM
Unionres's Avatar
Unionres
As a first time Ford owner I'm fairly skeptical, it hasnt been the greatest start with the second day of owning it i had the transmission hemmoraging fluid from the bellhousing. That issue should be resolved tomorrow night. It is a 1990 f250 460 e4od with whats believed to be 100k miles on the engine, tranny unknown. Any future problems i should look out for or any mods you kind folks would deem necessary.
Old Jan 25, 2017 | 11:30 PM
Scndsin's Avatar
Scndsin
Originally Posted by Unionres
As a first time Ford owner I'm fairly skeptical, it hasnt been the greatest start...
Welcome to FTE.
Congratulations. You have purchased a very large, gas guzzling, mechanically simple, but a fairly technologically complex vehicle that is now over a quarter century old (Think trying use a 286 intel pc running windows 3.1 to watch youtube)
Most of us here are enthusiasts & can deal. But since you did no homework before purchase & based on your opening, its almost a sure thing you WILL be massively disappointed.
Not being overly harsh, just a realist who's had a bad day.
Start with learning how to check codes (doesn't matter if you've got no CEL) & doing a search for "460" and/or "7.5" and "E4OD".
Then read for a few days.
Truly, welcome & good luck.
Old Jan 26, 2017 | 07:25 AM
jas88's Avatar
jas88
Trans fluid coming from the bellhousing usually means the converter seal is distorted from heat. Were you pulling something heavy with it? This does not happen in normal driving unless the seal has been damaged by previous overheating. I guess the person who sold you the truck did not mention this problem?
If you are having the converter seal replaced, be sure to use a blue or black colored seal. The gray seal is OEM and those are the ones that fail under heat.
Old Jan 26, 2017 | 08:19 AM
'89F2urd's Avatar
'89F2urd
From an optimist viewpoint, you have an awesome truck....long lasting, cheap to work on, big block power...like said above learn to pull codes (I don't particularly think it'll help you here but you need to know anyway) and start with that seal. Aftermarket Trans cooler is also a must on that truck.
Old Jan 26, 2017 | 08:55 AM
Scndsin's Avatar
Scndsin
Oh, I put the bit about codes in there rather than address the fluid because of this:
... Any future problems i should look out for?
If he can't get a pass code, (or is not tech savy enough to do it) well...
Old Jan 26, 2017 | 09:43 AM
'89F2urd's Avatar
'89F2urd
It was solid advice
Old Jan 26, 2017 | 10:17 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Well, you list the mileage at 50K-75K miles but say the engine has about 100K. Since the odometer doesn't read past 100K how many miles are actually on the truck? As mentioned it is almost 30 years old so any vehicle will have issues. What have you owned in the last?
Anyway there is a lot of knowledge here that can help you sort out whatever problems you have. Welcome.
Old Jan 26, 2017 | 10:59 AM
Freightrain's Avatar
Freightrain
The motor has 100K? The 460 is a good, solid engine and if it is taken care of it will go another 100K easily.
Sounds like the transmission has seen better days. Check fluid. Burnt smelling? Dark colored(instead of bright red).
Midwest Dually
Jun 18, 2016 11:47 PM
BrokeDownGarage
Jun 21, 2015 10:56 PM
pbgsho2
Jul 16, 2010 11:06 AM
trackenator
Jan 26, 2010 09:23 AM
Dstosh
Jan 16, 2009 04:16 AM
