Right, it's held down with a little 1/2 inch headed self tapping bolt
Painstakingly remove that clamp and install it on the new ground cable
That's what we had to do at the dealer back then
Now days, I think you can get that cable with the ground tab already on it
I bought a standard motor products one on rockauto first part of this year that had this I termediate tab. I see your air pump hose has be cut but the metal section left. It makes it a pain to get that screw out. Not sure if your air injection system. Is still intact, but if it is I highly recommend getting (2) 3/4 threaded bolts no more than 3/4" long and plug the heads.
