Replacment positive battery cable
Old Jan 9, 2006 | 07:34 PM
ggirten's Avatar
ggirten
I have a bad connector on the positive cable on my first battery. This is made on the cable itself. Has anyone tried cutting the cable and putting on ends like a boat battery? Where would you get another cable besides Ford? I better that would cost a few $$$.
Old Jan 9, 2006 | 07:36 PM
ford390gashog's Avatar
ford390gashog
you can just cut it and replace it. any parts store sells them.
Old Jan 9, 2006 | 08:18 PM
ggirten's Avatar
ggirten
I was wanting something a little beefier. Don't want it heating up from the load, although most is in starting and it has been loose for a while.
Old Jan 9, 2006 | 08:33 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
There are several types of replacement ends out there. Or you can buy a "premade" cable - just measure the old one, and buy one the same length, same wire size or heavier. Most autoparts stores sell them.
Old Jan 9, 2006 | 08:38 PM
ggirten's Avatar
ggirten
Most anything will be better than going to the stealership. Thanks for the info
Old Jan 9, 2006 | 09:22 PM
PSNut's Avatar
PSNut
Marine supply stores have some excellent quality electrical gear...give"em a check.
Old Jan 10, 2006 | 07:10 AM
ggirten's Avatar
ggirten
I've thought about the marine style. We have a crimper to put those style ends on the cable. If I can find a big enough piece for the battery, that is what I will probably do.
Old Jan 10, 2006 | 11:35 AM
RushN350's Avatar
RushN350
I replaced both of mine with solder on terminals from the local battery/alternator shop.
ligito
Apr 10, 2015 08:00 PM
78 & 87 Super Cab
May 20, 2014 04:27 PM
Frankiea87
Dec 26, 2013 04:40 PM
nebechanezer
Apr 19, 2013 07:01 PM
ckrichard
1997 - 2003 F150
Mar 4, 2005 11:24 PM
