BUZZERS??
Old Aug 10, 2025 | 09:46 PM
Land Yacht Garage's Avatar
Land Yacht Garage
6th Gear
BUZZERS??
Hey yall, 1983 Ford f250 here: i bought a buzzer to try to fix the one in my truck and i cant figure it out. There’s like 8 different forms telling me 6 different things. I just need to know weather or not I need to replace 1 or 2 buzzers? No sound when the key is in the ignition or when the lights are on. Found a small green buzzer behind the glovebox, but the part I bought (that’s supposed to fit) is a white box with a different pin setup. Did I buy the wrong part or is there 2 separate buzzers that need to both be replaced?
Old Aug 11, 2025 | 08:26 PM
FuzzFace2's Avatar
FuzzFace2
I dont know for sure so here is a bump ..........
I dont think there are 2 separate boxes just 2 different boxes depending how the truck was built and I think that may go by years, again not sure.
Now the only time my buzzer sounds is when I first turn the key to on or start it and the seat belt light is on.
BTW belt is not clicked yet as I do it after I back out of the garage or after I start it in a parking lot as I cant reach the parking brake with the seal belt on.
When the seat belt light goes out the buzzer stops.
I do wish at times when I leave the head light on a buzzer would sound as I run with the head lights on when pulling the car clubs trailer like Sunday.
I think that is where the other box comes in in the later years, mine is a 81 F100 Custom.
Do you have the seat belt wire plugged in? It is on the left side on the floor at the rear corner of the seat..
After I got my truck back on the road and the belt plugged back in it did not work for a while then 1 day it just started.
Dave ----
Old Aug 11, 2025 | 08:44 PM
kr98664's Avatar
kr98664
This is a long thread, but it has good details of the variations over the years:
https://www.ford-trucks.com/forums/1...-question.html
Old Aug 12, 2025 | 05:18 AM
Ken Blythen's Avatar
Ken Blythen
I've also got an '83 F250; it does have two separate buzzer units.......
One for 'light switch on/door open'.
One for 'ignition on/drivers belt not latched' (the seatbelt warning light shines simultaneously). This is meant to sound for 8 seconds after turning the ignition on.......it seemed like about 1.5 hours due to the horrific tone of the buzzer . I disconnected it behind the seat.
Old Aug 12, 2025 | 10:41 AM
Bronco638's Avatar
Bronco638
I have an '80 F-150. It has two buzzers located above the glove box door. One is white, the other is green. I'm tempted to remove them........
They do have different wiring connectors.
Old Aug 12, 2025 | 12:26 PM
FuzzFace2's Avatar
FuzzFace2
How many wires / pins are on the 2 plugs?
When I had everything stripped from both of my 2 - 81 F100's (custom & Ranger) only the Ranger had a buzzer for seat belt only no head light buzzer.
If I ever have my dash / glove box out again I will have to give a look see if there is another plug for the head light buzzer.
Dave ----
NitrogenTSRH
Oct 28, 2011 07:27 PM
kjg26
Mar 14, 2005 11:01 PM
estalder
Jul 5, 2004 09:45 PM
IES
Jan 31, 2003 07:24 AM
