Warning Chime
Old Oct 25, 2011 | 10:27 AM
NitrogenTSRH's Avatar
NitrogenTSRH
Warning Chime
I have a 1993 Ford Flareside 5.0L V8. There is no lights on, warning, or key in ignition chime, but I know the truck was equipped with it. The only thing that could be wrong here is fuses, right? Can someone please help me with this, I'm sick of locking my keys in the truck.
Old Oct 25, 2011 | 12:58 PM
Big_Al59's Avatar
Big_Al59
The buzzer module has probably been removed. It should be located under the dash, in the middle by driveline hump, ashtray area. If I remember right there is a large wiring harness it plugs into, if its there its a plastic box about 1x3". Should be able to search and find some pics. I removed mine years ago, got tired of the racket.
Old Oct 28, 2011 | 07:27 PM
Prof2113's Avatar
Prof2113
One other possible cause...I had an '87 ranger that spit out the lever/switch in the ignition cylinder itself. The chime never worked again. So if the box is there, and replacing it doesn't work, it might be one possible cause.
Christopher Workman
Jan 29, 2018 07:54 AM
DOUG5G
1983 - 2012 Ranger & B-Series
27
Nov 25, 2014 03:49 PM
qman
May 4, 2009 07:41 PM
kjg26
Mar 14, 2005 11:01 PM
nhood
Oct 9, 2004 04:18 AM
