Obd1 code troubleshooting
Old Jul 16, 2025 | 10:55 AM
BluWhale1957's Avatar
BluWhale1957
5th Gear
I have two codes that appear at medium to heavy load. They are 172 and 181 and i usually get spark knock while im under medium to heavy load. i run 93 octane so im fairly certain its not octane rating. im mechanical stupid so assume i don’t know much. thanks!
Old Jul 16, 2025 | 11:18 AM
wwhite's Avatar
wwhite
What engine?
Those codes could be from the following:
- exhaust leak
- vacuum leak
What condition is your exhaust? Does it have full exhaust?
Old Jul 16, 2025 | 11:31 AM
rla2005's Avatar
rla2005
Add low fuel pressure into a cause of those codes and pinging symptom.
Old Jul 16, 2025 | 12:26 PM
BluWhale1957
5th Gear
It’s got a 5.0 just had the muffler removed and new pipes added in its place. but it was doing this before that and is still doing it after.
Old Jul 16, 2025 | 12:27 PM
BluWhale1957
5th Gear
so maybe a fuel regulator?
Old Jul 16, 2025 | 12:41 PM
aquanaut20's Avatar
aquanaut20
Measure the flow and running fuel pressure.. Dont be guessing..
rla2005's Avatar
rla2005
Could be regulator, pump or a clogged filter. Process of elimination by testing.
Old Jul 16, 2025 | 01:18 PM
BluWhale1957
5th Gear
also idle is close to 1000 in park. just remembered that also
Old Jul 16, 2025 | 01:22 PM
wwhite's Avatar
wwhite
* points again to possible vacuum leak
Unplug IAC, does the idle change?
Old Jul 16, 2025 | 01:53 PM
BluWhale1957
5th Gear
dies immediately after i crank it
Old Jul 16, 2025 | 02:00 PM
wwhite's Avatar
wwhite
then the IAC is working, and probably not a vacuum leak.
Old Jul 17, 2025 | 04:52 AM
manicmechanic007's Avatar
manicmechanic007
Agree, check the fuel pressure and do a volume test
But
The upper intake gasket used to crack and come out on those early EFI 5.0's
Sometimes you can see the cracked gasket sticking out back behind the distributor
I'd sprat down the intake gaskets with some carb foam or brakleen and double check it for a vacuum leak
blinkerf150
Oct 7, 2022 03:47 PM
Da_Lariat_Chariot
Sep 10, 2017 08:55 PM
4x41977
Modular V8 (4.6L, 5.4L)
Apr 21, 2010 05:48 PM
Manwith3fords
Feb 28, 2004 10:58 AM
