Code 225 EEC IV
Old Sep 8, 2017 | 11:34 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Code 225 EEC IV
So I have a habit of running KOEO and KOER tests on a regular basis to check for any CMDTCs stored that may not turn the CEL on. I've been wondering about code 225 for awhile. In the description it says you must tap on the engine block to simulate a knock when prompted or code 225 (knock not sensed) will set during the KOER test. I have never gotten code 225 while doing the test but I have never tapped the engine when prompted. There is some piston slap when cold but the engine doesn't really knock otherwise so I'm wondering if that means something is wrong with the circuit and/or sensor. Thoughts?
Old Sep 8, 2017 | 12:41 PM
rla2005's Avatar
rla2005
When running the Dynamic Response KOER test the computer is programmed to expect a signal from the Knock Sensor triggered by pre-ignition/spark knock. You may not get any of that if you run higher octane fuel, retarded timing or live at a higher elevation.
If you are not getting any spark knock under normal operation I would not be concerned about getting a Code 225 when running the KOER tests.
Old Sep 8, 2017 | 12:43 PM
Da_Lariat_Chariot
You may have been in that thread I started awhile back where I was looking for help about my pinging noise. Unfortunately it still is occurring during heavy throttle.
Old Sep 8, 2017 | 03:57 PM
rla2005's Avatar
rla2005
I forgot about that thread. In light of that news....you may have a bad knock sensor. Finding the correct one is going to be tough. They are no longer made.
Testing one, no idea. I know they are designed to respond to certain frequencies based on the number of cylinders (I do not believe it is based on an inline versus V8). That's why the 4.9L version is a different part number than the 5L.
On the hand pinging at heavy throttle could be low fuel supply, bad injector(s), carbon build up or other items like wrong heat range spark plugs and a host of others.
I do not recall all the details from the other thread, that's why I prefer to just bump the old one by stating you still have the code even after doing x,y,z.....
Old Sep 10, 2017 | 08:55 PM
Da_Lariat_Chariot
The forward fuel pump stutters sometimes (I think it's on the way out) but I have measured no less than 35 psi from both front/rear fuel pumps while running. I ran a de-carbon spray that Motorcraft makes through the intake and the tail pipe smoked like a SOB. I have the correct Motorcraft plugs installed with an ACCEL coil, cap and rotor. As for the injectors I'm not sure. They had a reseal kit installed when I had the lower intake replaced ~2 years ago. Tried 91 octane briefly and it actually stopped pinging entirely for a few days but then came back.
court1100f
16
Feb 1, 2011 12:27 PM
pjlandry
Mar 4, 2007 08:09 PM
BigRedBronc
1978 - 1996 Big Bronco
16
Jan 15, 2006 08:23 PM
mugsy
Oct 29, 2004 03:25 PM
bricktop
1983 - 2012 Ranger & B-Series
May 4, 2004 07:27 PM
