I have two codes that appear at medium to heavy load. They are 172 and 181 and i usually get spark knock while im under medium to heavy load. i run 93 octane so im fairly certain its not octane rating. im mechanical stupid so assume i don’t know much. thanks!
also idle is close to 1000 in park. just remembered that also
Agree, check the fuel pressure and do a volume test
But
The upper intake gasket used to crack and come out on those early EFI 5.0's
Sometimes you can see the cracked gasket sticking out back behind the distributor
I'd sprat down the intake gaskets with some carb foam or brakleen and double check it for a vacuum leak
