very odd starting issue
Aug 4, 2025 | 06:34 PM
Bad computer most likely. If the computer does not see a string of PIP pulses the CEL will stay illuminated while cranking.
The fuel pump staying energized is another sign of a bad computer.
Aug 4, 2025 | 06:55 PM
i would assume the few times i have got it to start are just a fluke? and i should still assume bad ecm?
Aug 4, 2025 | 08:06 PM
Re-read your post and responses. I know what I would do. Your choice to proceed down your chosen path.
Sep 7, 2025 | 07:21 PM
well i finally had time to get back to this and i am in process of searching for a ECM so question is this my ecm part number is f4tf-12a650-aaa (hogo) all i can find seem to be F4TF-12A650-BB C does it truly matter aslong as it is from same year and a 5.0l engine?
Sep 8, 2025 | 07:11 AM
It does matter as far as which transmission is in the truck. HOGO is for a 5L/E4OD. F4TF-12A650-BBC (BUG2) is for a 5L/4R70W combination. Those computer are not interchangeable.
Sep 8, 2025 | 07:59 AM
ok that figures guess it is time to start looking online then
Sep 26, 2025 | 09:07 PM
ok as long as it is a hogo from a 5L/E4OD should it work? I just came across a F4TF-12A650-AP A local just hate to go pick it up and just cause more issues
Oct 2, 2025 | 11:35 AM
F4TF-12A650-APA has Catch Code HUG0. It is designed for trucks with a 5L/4R70W combination.
Oct 2, 2025 | 11:46 AM
drats wrong transmission back to the hunt
Oct 21, 2025 | 04:29 PM
well I finally found a ECU local and it tries to start but won't fully start. Any suggestions on what to check besides the timing?
Oct 21, 2025 | 04:42 PM
What ECU? Show pictures?
So, you changed he ECU and you have the same problem?
Oct 21, 2025 | 05:45 PM
No, before the ecu replacement, it just spun. Now it tries to start but never seems to get there be able to stay running if that makes sense
Quote:
Originally Posted by
wwhite
elyrain
Nov 1, 2025 05:16 AM
ironmine
Apr 19, 2008 10:19 AM
2000 F-150
1997 - 2003 F150
Apr 20, 2005 08:15 AM
voodoosmooth
Dec 9, 2004 10:04 AM
KJUNDAD18
Oct 29, 2004 11:15 AM
