Sponsored by: Auxito
Code P1400 - DPFE Low Voltage
Old Apr 19, 2005 | 11:16 PM
2000 F-150's Avatar
2000 F-150
Question Code P1400 - DPFE Low Voltage
Does anyone know what the symptoms of this code would be? I've read various posts that say a bad DPFE could trigger misfire symptoms, rough idle, etc., etc. I've been periodically checking for codes after reading that a code could be stored without a CEL and bingo! I finally got the little !#%^$#@!
Old Apr 19, 2005 | 11:25 PM
Perfection's Avatar
Perfection
check the ground, make sure its grounded correctly, if its a real problem (don't know symptoms) you can get bigger awg wire and ground it with a shorter ground and your V~ should go up.
Old Apr 20, 2005 | 08:15 AM
projectSHO89's Avatar
projectSHO89
Saw your post first on the other forum and answered it there.
Steve
YellowXLT
Jul 5, 2015 06:09 PM
77mud
1997 - 2003 F150
Jun 15, 2013 07:37 AM
Spaded_Z
29
Jan 22, 2013 03:28 PM
dale88
Jan 25, 2009 02:03 PM
piedmont
Aug 16, 2007 10:07 AM
