Anyone here experienced with portable generators?
Old Jul 7, 2025 | 04:05 PM
wpg_250's Avatar
wpg_250
Picked up this Craftsman 2200i for $350 and it sounds like it's bogging down when in normal run mode.
Other vids of the same unit on youtube sound similar so not sure if this is normal or something is off?
Maybe the cap isn't venting properly or the carb needs a good cleaning?
Any ideas folks?
Old Jul 8, 2025 | 01:11 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What is the voltage showing while this is happening?
Does it do the same thing with a significant load on it?
Old Jul 8, 2025 | 06:58 AM
wpg_250's Avatar
wpg_250
I gave it a good cleaning and it seems to be running fine now, load or not. Only ethanol tainted fuel up here so I'll have to start adding a cap or two of Seafoam to every tank and or start "washing" the ethanol out of the gas which will be a PITA lol. If they sell propane conversion kits for this model then I'll buy a kit and a new carb and start fresh with new parts
Old Jul 8, 2025 | 08:21 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by wpg_250
https://www.youtube.com/shorts/gJHf7FJfUWY
You bought a used generator with a dirty carburetor probably from setting with gas in the carburetor. You put 10% gas in it so just what alcohol does it started cleaning it out causing your rough running. If you cleaned it out the 10% will keep it clean. Never leave and gas in a generator allowing it to evaporate. I run 10% in all my small motors and without problems and have for years.
Denny
Old Jul 8, 2025 | 08:50 AM
wpg_250's Avatar
wpg_250
Denny
I didn't do anything to the fuel.
Old Jul 8, 2025 | 09:46 PM
CathedralCub
FTE Community Team
Great news!
Old Jul 8, 2025 | 11:04 PM
wpg_250's Avatar
wpg_250
Great news!
Not bad for $350 eh.
Old Jul 10, 2025 | 09:37 AM
HRTKD's Avatar
HRTKD
The higher the elevation, the less HP it has which translates to fewer watts generated.
Old Jul 10, 2025 | 11:18 AM
WE3ZS's Avatar
WE3ZS
I bought a pair of the similar Honda EU2000 generators 15 years ago, they have been used for powering 3 different campers while dry camping, power for air comp and tools at the track and power at home during storm related outages. They have sat for 6+ months at a time several times and have only very rarely been run empty of gas before sitting, have only ever run on E10 gas and have never had any issues starting or running. I wouldn’t convert to propane, gas is much more convenient and easier to refuel. When powering the campers I do use a 6.5 gallon marine fuel tank with the outlet split to the 2 gennies, as they consume gas they draw fresh from the marine tank, the 2 link together to provide 30 amp service. Running a single 13.5K BTU AC and normal house loads on our fiver the marine tank will still have just under a half tank after morning coffee after being setup around dinner time the day before.
Old Dec 15, 2025 | 04:20 PM
ken235's Avatar
ken235
Are you running the two generators at the same time on the same buss. Like running them in parallel?
I have two 5kw generators. Was curious if running them both together on the same breaker was a safe idea.
Seem to me that they need to be at the same frequency or with in a certain % tolerance to to be used like that.
Old Dec 15, 2025 | 07:11 PM
WE3ZS's Avatar
WE3ZS
Yes, both together at the same time feeding the single 50 amp inlet on the camper but via a 30 to 50 amp adapter. BUT……..these little Hondas are designed for this application, one serves as the master and the other supplements it via linking cables between them. With them hooked together they can supply a full 30 amp RV service and are very stable. If your two generators are not designed for this setup I don’t think linking them together would be a safe bet.
Old Dec 16, 2025 | 08:59 AM
koolhandluke1's Avatar
koolhandluke1
Probably a moot point since you seemed to
have it fixed, but in my experience propane generators aren't as efficient as gasoline and potentially hard starting in cold weather. Given a choice, I would stick with the gasoline. My Hudson 3300i will run for days with the 1 gallon internal tank and 2 gallon can I carry with me and powers everything in my 30amp slide in with ease if I manage the load. I drain the fuel and run it dry when laying it up for any length of time.
Old Dec 18, 2025 | 12:35 PM
wpg_250's Avatar
wpg_250
It runs a bit rough for the first few minutes, but if I throw a load on it right away it smooths out a lot faster so come spring I'll run some non ethanol gasoline through it with some kind of de-cruding additive and go from there.
Old Apr 28, 2026 | 12:25 PM
speakerfritz's Avatar
speakerfritz
https://www.youtube.com/shorts/BCXkWYUKDv0
Any ideas folks?
jets cleaning
valve clearance adjustment
the layer if it sounds like it’s hunting
these generators do wear out and perform sluggish as they age.
awf1502018
2015 - 2020 F150
Sep 23, 2024 10:21 AM
lupuseven
Apr 2, 2014 07:48 PM
jav409
Dec 5, 2004 09:59 PM
EquineGuy01
Exhaust Systems
Nov 13, 2004 08:40 AM
hickstick_10
May 26, 2004 05:19 AM
