Singing Holley ?
Old Dec 2, 2004 | 08:23 PM
jav409's Avatar
jav409
Singing Holley ?
I have a 352 Fe with a Holley 500cmf 2 bl carb, the jetting is correct, and the motor runs good, But I get this singing sound from the carb when it running down the road, it sound like the sound you get when the accelerator pump is depressed ( you know that kinda bakon frying sound when the air rushes across the venturi's, Is this sound normal for a Holley ? Are they usally this loud ? ( i can hear it in the cab ). I may be worrying over nothing, It has been years sence I owned a Holley and age will not let me remember if that one did it or not.
Thanks.( the carb is out of the box new, with jetting changes. It has made this sound from the begining.)
Old Dec 5, 2004 | 05:53 AM
jriley301's Avatar
jriley301
Does it sound like air? make sure no vacuum leaks. I hate the holley rebuilds.
Old Dec 5, 2004 | 10:43 AM
Chas1234's Avatar
Chas1234
do you have an open element air cleaner ?
My 350 cfm holley on my 360 is noisy at some road speeds . I wouldnt worry about it drive it and have fun.
Old Dec 5, 2004 | 09:59 PM
jav409's Avatar
jav409
Yes a large open element Air cleaner, Thanks , As for rebuilds this one is new out of the box the only change I have made it rejet for my motor and adj accelerator pump clearance and flot level.
