E4OD, no first gear.
Old Jun 19, 2025 | 02:06 PM
Rasputin53's Avatar
Rasputin53
90 F-250 HD, 460, 148k miles. No kidding. First gear was getting lazy, taking longer and longer to get up to speed. Then, after towing a small trailer - with nothing in it - first all but disappeared. Pump is pumping, because I spool up with little motion in 1st and then when 2nd engages, the truck goes. No thunks. No codes. Just no power transfer in 1st. So I drop the pan to see if there's any evidence and I find these four slivers. About a half inch long. Look like bits of bearing cage. Not sure it's related. Usual filings around magnet, and not that much actually. Before I got this truck, someone put new seals in it and that might be the only fluid change this truck has ever had. I'm guessing clutches and frictions are toast. Fluid was dark, but did not smell burnt, still, not good. Looks like I might be rebuilding my first E4OD.
Old Jun 19, 2025 | 03:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored in the PCM?
Old Jun 19, 2025 | 03:53 PM
Rasputin53's Avatar
Rasputin53
No codes.
Old Jun 20, 2025 | 09:44 AM
1Butcher's Avatar
1Butcher
There are a lot of updates for a 90. Maybe find a newer core/used one and go through that. That way, it's just a swap out once your done going through the transmission. There are plenty of YouTube video's that show how to D&A the transmission. The transmission bench has a good one, but it's way too boring. Certainly worth watching if you have never done a transmission before.
The term rebuilt is used too often and wrongly used. Repairing is the term I use when I fix a transmission. Most shops and certainly DIY's don't have the tools/machines for a complete rebuild.
Old Jun 20, 2025 | 04:37 PM
Rasputin53's Avatar
Rasputin53
That would be nice, but there only seems to be an abundance of 7.3 and 5.8 versions readily available. Still looking.
460FordBaby
25
Jul 11, 2025 12:13 PM
icrman
Jun 29, 2022 08:03 PM
Mason94f150
Jun 21, 2014 03:10 PM
tpcgregsheh
Sep 8, 2010 07:57 AM
Tren
1978 - 1996 Big Bronco
Aug 26, 2009 04:37 AM
